Attention AvChat! My next plane will be a... | Page 3 | FerrariChat
Discussion in 'Aviation Chat' started by snj5, Jul 16, 2009.
  1. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #51 Spasso, Sep 7, 2009
    If you were going for an L-Bird I would settle for nothing less than the L-5.
    Big enough, good payload and power.
    The latest development.
  2. Island Time
    Island Time F1 World Champ
    12,163
    E. TN
    David
    #52 Island Time, Sep 8, 2009
    I've like to fly a Fleet. A little more rare, but they are around and prices seem affordable. For some reason these planes have always piqued my interest. I think it's the honesty/simplicity of the lines of the plane.. Kind of "Stearmanesk", but seem a little more managable as far as size goes. Probably less practical than an Aeronca though. Don't know about LSA, but these things don't look like they weigh all that much
  3. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    I've also been bitten by the plane bug lately, unfortunately, the wife is much more adamant against a plane than a fourth Ferrari...
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #54 snj5, Sep 12, 2009
    After much research, and as many of you have deduced, I am electing to build a full size replica of one of the iconic dream planes of my early youth, the Sopwith 1.F.1 Camel. I have opted for a more modern engine for safety and to allow radio communication (can't use a radio with a rotary engine), but one that has the same power. So I have just purchased last week a 150 hp Rotec 9 cylinder radial that will swing a 90" propeller. I will be using the original aircrafts's rudder bar flight controls, approximate airfoil, wing areas, incidences and dihedral from the Replicraft plans of Mr. Kiger. I now also have access to Roger Freeman's local extensive references to the Camel, including factory drawings, and am locating original instruments as available. I've started a local lady replicating a wicker seat from photos and blueprints. Being a big giy, I have determined the 27"+ inter longeron width should allow a comfortable cockpit, about like a Champ. We are shooting for E-LSA eleigibility which gives a lot of advantages. There is no kit, but will be working with Robert Baslee who has built similar aircraft before. Other concessions to safety will be a welded steel tube frame to supplant the wooden airframe, and horror of horrors, brakes, so I don't run into anyone on the ramp.
    While I am already buying raw materials, this will take a while to do. For me, this has always been a dream aircraft, much the same as a Corsair. And the LSA eligibility and running costs have a lot of advantages for a government pensioner. There is a former F-15 Sqn commander in Houston with a full size Nieuport 28, so we are planning some formation trips (s-l-o-w :) )
    Here we go. All advice welcome.
  5. zygomatic
    zygomatic F1 Veteran
    5,107
    Washington, DC
    Chris
    That is fantastic! I'll be the first to beg you to send snapshots/plans and document your build.
  6. tazandjan
    39,388
    Russ- Sounds like great fun and the steel tube fuselage will make it much easier to build. You almost needed to be a master furniture maker to build the original fuselage. Have fun and see you in October. I will be the short, chubby bald-headed guy.
    Taz
    Terry Phillips
  7. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Well, nobody can ever say you do things in a small way. This will be a fabulous airplane when you are done based on the work you've done with the Mondial and restoration of the T-28 cockpit.
  8. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Thanks all.
    The devil is certainly in the details. The WW1 British planes were the first to use streamlined flying wires, and will be having a set of those made. Don't know how much, but am told there is a 10x difference in drag over regular wire. I'll need every knot with 231 sq feet of wing and 150 hp! Only one supplier in the states - Steen Labs - and they get them from the one manufacturer in England. Will be ordering once we verify the measurements.
    And true to form, I've already sourced the two Vickers .303 ...
  9. donv
    donv Two Time F1 World Champ
    26,374
    Portland, Oregon
    Don
    How much power did the original have?
    Also, are you going to have a tailwheel, or use a skid?
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    It's not how much hp, but how much torque. The Camels had engines from 110 - 170 hp (typically a 130 hp Clerget), but it was achieved at 1300 rpm yielding massive torque and allowing the use of the large wide chord propellors.
    Not sure about the skid, yet.
  11. tazandjan
    39,388
    Don- Original Camels used a wide variety of engines, including the 130/140 hp Clerget, the 120 hp LeRhone 9Jb (110 hp iron pistons, 120 hp aluminum pistons), the 150 hp AR/BR-1, and the 160 hp Gnome 9N.
    Taz
    Terry Phillips
  12. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    The tail wheel would hurt the authenticity but I think it would be a huge plus in taxiing/ground handling.
    What about brakes though?
  13. tazandjan
    39,388
    Russ- There are some very clever tailskid designs that have a small wheel between two outside skid pieces/axle holders that are very difficult to see unless you are very close to them. The tailskid was the only brake for most WW-I designs, except for some German two seaters that had a pull-up-to-engage claw brake on the bottom of the axle.
    Taz
    Terry Phillips
  14. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #64 snj5, Sep 12, 2009
    I am studying hard, and amazed constantly at the cleverness of the original designers as well as replica builders. The skid thing sounds good - any refrences? Looking fwd to seeing you at OTF; I will also be at Dayton for the September WW1 fly-in if anyone is going.
    There are some intresting well documented field mods made to the Camel I've found and going to incorporate, one being the removal of the wooden front section over the guns and enlargement of the cockpit hole to allow easier gun servicing. Well, it also makes ingress/egress easier and more comfortable for this non-WW1 sized pilot. As usual, there were also differing interpretations of the general order. Here is a photo of an original specification cockpit, and two with the field modification taken from wartime photo based builds. The last replica, Peter Jackson's replica in NZ, can be identified in the cockpit shot as having the later Bentley BR-1, by the ignition variator on the right lower panel - it varies the number of cylinders firing as a way to select engine power.
    I used to have an Alfa Romeo that did that on its own.
    A few cockpit inches does make a huge difference.
  15. tazandjan
    39,388
    #65 tazandjan, Sep 12, 2009
    Russ- The various schemes for lowering horsepower on the Gnome 9N and some other WW-I engines did not cut out cylinders, they varied the firing order so all cylinders were still firing, but at a much slower rate. A pretty good explanation is contained in Fred Murrin's article on the Gnome 9N for Over the Front. Fred actually won a writing award for this article. Can provide the photos later if anyone is interested.
    Taz
    Terry Phillips
  16. Fastviper
    Fastviper F1 Rookie
    Nov 20, 2003
    4,525
    Texas
    Dash
    That is some pretty interesting stuff right there...
  17. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #67 snj5, Sep 12, 2009
    Yes - that is what I meant. All cylinders fire but it ends up being every other, every x, keeping even spacing etc, around the firing order till all have fired. That is also what my Alfa did on its own, but in a more random selection... :)
    If you have any photos of Mr Murrin's Camel, would love to see them.
    Many thanks.
  18. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Fuselage tacked up, will start welding tomorrow; WW1 altimeter off ebay arrived (it works), now looking for compass and airspeed indicator. Throttle quadrant in the mail; engine ordered from Australia.
    I wish I could get one of the few new production Oberursels or LeRhones, but they are all spoken for, and or years away from completion.
    Will be at the National WW 1 fly-in at Dayton at the USAF Museum 26 Sept if anyone going. I'll be the guy with camera, tape measure, notepad and shopping bag.
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #69 snj5, Sep 14, 2009
    Hey, pilots out there!
    WW1 planes used an inverted inclinometer with a bubble in the top of it.
    So, stepping 'on the ball' is the same as stepping 'away from the bubble'?
  20. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Yes, if the aircraft is rolled ccw, you apply left rudder, and the bubble would be to the right so you would be still applying left rudder and stepping away from the bubble...
    Somehow that looks counter-intutitive, stepping "on the ball" seems natural, but, more likely it is going to be whatever you learned will feel natural... Maybe if you look at as pushing the airplane "under the bubble" it will feel natural...
    Then again you always see videos of WW1 aircraft rocking wings and nose hunting left and right, maybe they pilots are screwing up and pushing the wrong pedal and then saying "oops!" and then getting it right...
    BTW, I and a friend of mine who owns Cleveland Model and Supply were planning on going. Since we are only two hours away we were going to pick our day based on the weather, but if it holds for Saturday, we will be there at the same time, I'll pm you a cell phone number.
  21. tazandjan
    39,388
    SF- Friday or Saturday is always a better deal. Gets really crowded on Sunday and many people are already shutting down for the trip home.
    Taz
    Terry Phillips
  22. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    #72 solofast, Sep 15, 2009
    Taz,
    Thanks, we were figuring that might be the case, that folks would be starting to knock down by Sunday, you hate to miss anything we will try to hit Saturday if at all possible.
    The last time I was there was 2003. There was a very accurate DR-1 with a LeRhone in it that we got to see fly it was very cool. There was also a wood fuselage Albatross that was being built that was on display, tremendous amount of work involved, had an original engine for it.
