Audi Noise | FerrariChat
Audi Noise
Discussion in 'Other German' started by lor2435, Jan 24, 2013.
  1. lor2435
    lor2435 Formula 3
    Nov 6, 2005
    1,009
    NYC
    Hey guys, I have an A4 with a 5speed and its started to make a squealing noise when I accelerate. It happens in 1st and 2nd when accelerating from a very low speed or completely stopped. It sounds rotational and gets faster until it goes away completely at about 20mph. It happens both letting off the clutch and with the clutch fully engaged.
    The noise produces no vibrations. I must have a belt slipping, right?
  2. photonut
    photonut F1 Rookie Owner Rossa Subscribed
    Nov 16, 2007
    4,080
    Michigan
    Joel
    sounds like it to me.
    i would have it checked out at the dealer.
  3. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    Sounds like a belt slipping. As a test put some baby powder on the inside. If it is belt slippage that should stop it from squeaking for a few weeks. It is not a long term fix but you will know what it is.
    I personally do not own an Audi but if you press on the belt midway it should deflect about a 1/2 inch or so. If you chose to adjust the belt yourself be careful not to make it to tight. You could damage a bearing on something.
    Good luck
    Lee
  4. etmracing
    etmracing Karting
    Oct 17, 2010
    206
    Thurmont MD
    Marc Stephens
    I replace a fair number of belt tensioners on Audis in my shop. Just did one this morning
  5. lor2435
    lor2435 Formula 3
    Nov 6, 2005
    1,009
    NYC
    Thanks guys. Any chance it could be clutch related?
  6. etmracing
    etmracing Karting
    Oct 17, 2010
    206
    Thurmont MD
    Marc Stephens
    Is this a quattro car?
  7. lor2435
    lor2435 Formula 3
    Nov 6, 2005
    1,009
    NYC
    Yeah it's a Quattro.
    The noise doesn't seem to cause any vibration but seems to be getting louder.
