Aussie Ferrari Spotters Thread?? | Page 163 | FerrariChat
Discussion in 'Australia' started by v15ben, Jul 16, 2005.
  1. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    hahaha :D
  2. FFOUR
    FFOUR F1 Veteran
    Sep 14, 2004
    5,195
    Perth, Australia
    Pete has one and is a pretty tall guy, don't think he has any probs.....you can't be that tall.
  3. JoeK
    JoeK Formula 3
    Aug 23, 2005
    1,080
    328 wtf you going senile or going through menopause?
  4. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Both. :)
  5. JoeK
    JoeK Formula 3
    Aug 23, 2005
    1,080
    Could carl reach the peddles ?
  6. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    i think a 5 year old could reach the pedals...REACH is not a problem...ROOM is a major one.
  7. jim501
    jim501 Formula 3
    Mar 29, 2005
    1,085
    Gold Coast
    Well you should be happy you were actually able to get them apart though!!
  8. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,757
    Australia
    I did actually, found a way just after you left, doh!
    all I need to do now is bleed them and it's onto the front brakes .... oh joy
    the brakes are so tiny that you wonder how they slow a 1410kg car down , and they do it lap after lap (10 lap stints) at QR which is very hard on brakes ... well I use them turn 1, 3, 4 and 7.
    A good driver would only use them on turns 3 and 7 but it would be a ballsy lap :D
  9. scud
    scud F1 World Champ
    Oct 2, 2004
    11,803
    err no number 7
  10. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
  11. moretti
    Nov 1, 2003
    59,757
    Australia
    I was counting the double apex turn as 2, I have to turn the wheel twice so that's 2 by me :D
    or is that oversteer ?? :D
  12. scud
    scud F1 World Champ
    Oct 2, 2004
    11,803
    the double apex turn is 4 and 5 . still makes only 6 total
  13. moretti
    Nov 1, 2003
    59,757
    Australia
    ok then, my laps are 2 over par .... same handicap as golf (per hole)
  14. jim501
    jim501 Formula 3
    Mar 29, 2005
    1,085
    Gold Coast
    Not sure what I'm up to this weekend I'll let you know. Unless you're need them earlier and take the gamble of getting some air in there :p
  15. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    one-man-bleeder kits werk great. $7 bucks from roccas.
    or adapt a lid to fit onto the brake reservoir so it accepts a bike-pump, screw it on, crack the nipple, start pumping!
  16. moretti
    Nov 1, 2003
    59,757
    Australia
    would save a lot of family fights, never used one before, do they do a good job ?
  17. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    i just did my clutch with a mate last week, that took about 45 mins because of access difficulties with getting at the nipple (had to remove water reservoir and still couldn't see it with both eyes), then the procedure: crack, yell "dump it", tighten, yell "pump it", repeat until all the air was gone and fluid running cleaner.
    a couple years ago when i did the bleeder, a one-way valve goes into the nipple and goes through a tube into a collector with a magnet on it. whack the collector somewhere, crack the nipple, shove in the valve, go and pump it some, check the tube for air bubbles, check the reservoir for fluid level, repeat until fluid is solid and clean. total time about 5-10 mins.
  18. goober
    goober F1 World Champ
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    the velvet glove does the same service from Q club or mars bar
  19. PAP 348
    Dec 10, 2005
    100,220
    Pap
    You can make your own self bleeder kit JM. Use an empty 600ml coke bottle, fill it half way with new brake fluid. Drill a little hole in the top of the cap, and feed a little bit of window washer hose through to the bottom of the bottle. Then attach to your bleeder nipples, crack the bleeder, jump in the car and pump away(do around 5-10 pumps) Then tighten the nipple back up. :) Thats the Bush Mechanics way of doing things. :p
  20. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    #4070 ferrarifixer, Jun 15, 2006
    pfft.. what d'you mean "brake fluid".... detergent and water is fine....
  21. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    omo
  22. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    can you tell?
  23. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    no, but my oyfriend can
  24. moretti
    Nov 1, 2003
    59,757
    Australia
    oi!!
    you don't know what his sexual preference is .....
    he might be straight ..... lives in Melb, probably not :rolleyes:
  25. moretti
    Nov 1, 2003
    59,757
    Australia
    what about 4x2s ?
    I get a woody looking at my 3x8qv :)
    even PP is driving around in a 3x8GTS at the mo
