Auto dimming mirrors on F8, how to disable? | FerrariChat
Discussion in '458 Italia/488/F8' started by S.R, Jul 14, 2025 at 12:25 PM.
  1. S.R
    S.R Rookie
    Jun 19, 2021
    13
    My 2022 F8 spider seems to have auto dimming mirrors, for both the rear view mirror as well as the side mirrors.
    Does anyone know how to turn these off? My windows are tinted, and when the mirrors dim, it makes it increasingly difficult to see anything.
    I also have my radar detector hanging from the mirror, is there a light sensor there that is being blocked or something?
  2. Phelips
    Phelips Karting
    May 30, 2025
    59
    Russel Phelips Brown
    The auto-dimming mirrors in your F8 Spider can't be manually turned off they're controlled by light sensors (likely in the rearview mirror). Your radar detector might be blocking the sensor, causing excessive dimming. Try repositioning it to see if that helps. If not, check with Ferrari if they can disable it via software, but most owners just live with it. Tinted windows + dimmed mirrors do make visibility tough at night.
  3. Snapshift
    Snapshift Formula Junior
    923
    Centralia IL
    Lyle D. Pahnke
    #3 Snapshift, Jul 14, 2025 at 10:21 PM
    If you can get the actual rearview mirror opened and apart, there is a 4 pin plug with a green, black and red wire to the motherboard. Inside the mirror. On the 458, there is a button on the bottom of the mirror that turned on or off the electrochromic dimming of the mirrors. If no button, your best bet is to unplug the aforementioned plug to disable the mirror dimming. I don't know if it will introduce an error message, but on my 458, it disabled the mirrors by removing the plug. I suspect that the mirrors are much the same on your car but can't be sure. GLWT.
    BuyHighSellLow likes this.
