auto shifting problem, not a ferrari | FerrariChat
Discussion in 'Technical Q&A' started by fanatic1, Jun 3, 2006.
  1. fanatic1
    fanatic1 Guest
    Nov 1, 2003
    561
    columbus
    philip
    Hi guys, this isn't a ferrari, but I am sure someone on here can help. My niece has an automatic Ford. It was driving fine, then last night after she parked, she went out to start the car. The car starts and "runs fine", however it won't shift at all. the Automatic Shifter will move from Park to Drive and through reverse, however NOTHING happens the car doesn't move at all. The shifter also feels a little more "loose" or easier to move than it did before. Of course I checked Transision fluid, and it's fine. Any ideas a all?
    thanks
  2. zan
    zan Formula Junior
    Nov 15, 2002
    537
    Boston
    Mark M
    First thing I would check is the shifter cable
  3. fanatic1
    fanatic1 Guest
    Nov 1, 2003
    561
    columbus
    philip
    Thanks Zan,
    Is that easy to do? All of my cars are manual trans, I've never had an auto. If I take off the whole center console piece and expose the guts of the shifter will I be able to see it from there, or is this something that has to be checked on the underbelly of the car?
  4. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    I would think it would be easier to check from the bottom. Chock wheels, jack up & use jack stands then have someone move shifter & see if it moves lever on transmission. If this is a front wheel drive car u can just open hood & check for lever movement.
  5. fanatic1
    fanatic1 Guest
    Nov 1, 2003
    561
    columbus
    philip
    Thanks billy,
    It is a FWD......so I'll do that soon, I'll start it up and move the shifter back and forth....I should see a lever moving right? Just look near/at the trans??
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You don't have to start the car. It's just a cable or rod. Either it moves when you move the shifter or it doesn't. If it doesn't, then reconnect it or repair/replace it.
