488 - Auto versus paddle 488 | FerrariChat
488 Auto versus paddle 488
Discussion in '458 Italia/488/F8' started by King, May 21, 2021.
  1. King
    King Rookie
    Jul 13, 2004
    34
    Florida
    Michael Metzler
    Anyone see or compare, 1/4 times between leaving it in Auto or Manually Paddle shifting?
    You would think Auto would be a perfect RPM, every time or Shift.
    Paddles would have driver error.
    Thanks.
  2. As opposed to just using launch control?
    King likes this.
  3. SVR
    SVR Karting
    Feb 9, 2017
    195
    Moscow, Russia
    LC-mode times much better.
    Gears shift automatically in this mode
    LVP488 and King like this.
  4. King
    King Rookie
    Jul 13, 2004
    34
    Florida
    Michael Metzler
    What about at a matched RPM from a roll? Will an Auto or Paddle give you quicker acceleration through the gears?
    (I know which is more fun! [emoji876])
  5. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Unless you have a dyno sheet with the torque numbers, it will be difficult to calculate the best shift points. A car often gets slower if you shift at redline because you end up changing down to a place in the torque curve where peak torque has dropped off.
    This is why the car is maxed out when using LC. Ferrari has put the shift points at the optimum places. Some complain that the car might be slower because it does not rev out in each gear, but that's just nkt the case and they lack the knowledge of what's going on.
    See where the car shifts gears during a launch, that will tell you where the best shift points are - at least as,a ballpark estimate. If you just wring it out in each gear, you will not be fast.
  6. Cigarzman
    Cigarzman F1 Veteran
  7. King
    King Rookie
    Jul 13, 2004
    34
    Florida
    Michael Metzler
    In PS mode, don’t you have the option of using Auto or Paddle?
  8. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,478
    Tampa FL
    This was proven by Brooks on Dragtimes. Launch Control and auto shift was best 1/4 mile and 0-60 etc times.
    King likes this.
  9. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,924
    France
    But my understanding is that Launch Control is the only set-up where automatic gear changes are optimised for performance - meaning that apart with LC from a standing start, one is likely to achieve better performance if shifting manually (and in theory one should be able to manually match the auto LC, although it may be pointless).
    King likes this.
  10. King
    King Rookie
    Jul 13, 2004
    34
    Florida
    Michael Metzler
    The 488 has to have Auto off to use PS (Launch Control).
    Will it shift automatically from manual mode using PS or will 1st gear bounce off the Rev limiter.
    Not much time to control spin, watch road and shift out of 1st from PS (3000rpm) take off.
    Add in my white tach, where you can’t see the numbers on a bright day.
    Aces..
  11. Eric C
    Eric C F1 World Champ
    11,088
    St. Louis, MO
    Eric
    I noticed this tonight while using dragy. I was using PS and was wondering why the hell it was shifting for me.
