Autocar Article 599 | FerrariChat
Autocar Article 599
Discussion in '612/599' started by TBond8, May 11, 2006.
  1. TBond8
    TBond8 Karting
    Feb 7, 2006
    136
    CT,CA, Europe
    Thomas
    Autocar out of the UK seems to have a cover story about the 599. I have not seen it in any stores yet. Has anyone seen it and or read the article? I am hoping to pick it up soon.
  2. admcewen
    admcewen Karting
    May 3, 2005
    103
    West Suffolk
    Adam McEwen
    I've got it. Basically Andrew Frankel drives it and loves it writing that it is the "best production Ferrari for 20 years". He says the gearshift is so fast that he "does not perceive the space between the gears". He claims that it is only 1.5 secs slower around Fiorano than the Enzo. In race mode he writes "it becomes other-worldly"
    At the same time Chris Harris is driving a 911 turbo then they contact each other by mobile and compare. The first text that Andrew sends is "Bloody hell this thing looks good" Otherwise the arguement seems to conclude that really both cars are as good as each other (the Porker being faster in bad weather and the Fezza being faster in a straight line) but that the 599 has more....passion and excitement built in, Chris wrote that the Porker although very good "it never feels bespoke, you dont feel special driving it"
    Also one thing I noticed that although a smaller car the 911 is 6 kilos heavier. Ok so not much but it is a much smaller car than the 599, Porker indeed!!
  3. nejcdolinsek
    nejcdolinsek Karting
    Dec 2, 2003
    211
    Thanks for the heads-up!!!
    I'm going to buy it......... NOW! :D
    I hope I'll get the article up ASAP :)
  4. admcewen
    admcewen Karting
    May 3, 2005
    103
    West Suffolk
    Adam McEwen
    Cheers mate I don't have a scanner of my own.
    Also Irealised I made a mistake the 911 is 6 kilos lighter but still only 6 kilos for a car that is a lot smaller.....
  5. nejcdolinsek
    Dec 2, 2003
    211
    Damn damn damn!!!!
    My local store doesn't have it yet! :(
  6. TBond8
    TBond8 Karting
    Feb 7, 2006
    136
    CT,CA, Europe
    Thomas
    I just checked to see if Autocar website has it up yet. No luck. I am also going to check to see if my local store has it yet.
    Thank you for posting the opinions of both 599 and 997 TT from Autocar.
    Thank you again.
  7. bostonmini
    bostonmini Formula 3
    Nov 8, 2003
    1,890
    6 kilos heavier??? that doesnt seem right:(
  8. alin13
    alin13 Karting
    Jan 1, 2006
    230
    Just 6kg difference between them? that can't be right, what figure did they publish for the weight?
  9. admcewen
    admcewen Karting
    May 3, 2005
    103
    West Suffolk
    Adam McEwen
    I know what you mean the figures are thus:
    599GTB: 1579Kg
    997TT: 1585Kg
    So actually I was right to start with oops..
  10. amenasce
    34,433
    Joe Mansion
    Autoexpress mentionned a 1670 kgs weight or so ?
  11. admcewen
    admcewen Karting
    May 3, 2005
    103
    West Suffolk
    Adam McEwen
    I'll take Autocar over Autoexpress anytime when it comes to figures
  12. alin13
    alin13 Karting
    Jan 1, 2006
    230
    Wow, that's intersting. Even Ferrari's official figure is 1690.
  13. TBond8
    TBond8 Karting
    Feb 7, 2006
    136
    CT,CA, Europe
    Thomas
    I finally found the autocar article. I have not finished reading it yet. I will say from what Andrew Frankel writes he does like the 599.
    Here are some of the stats;
    599 997TT
    Price 175,000(Pounds est.) 97,840
    0-62 mph 3.9 sec 3.9 sec
    0-125 mph 11.0 sec 12.8 sec
    Top Speed 205 mph 193 mph
    Power 611 Bph@ 7600 rpm 473 Bph@ 6600 rpm
    Torque 448 lb Ft @ 5600 rpm 457 lb Ft @ 1950-5000 rpm
    Power to Weight 392 Bph / Ton 299 Bph / Ton
    Torque to Weight 283lb Ft / Ton 288lb Ft / Ton
    Length 4666mm 4450mm
    Width 1961mm 1852mm
    Height 1336mm 1300mm
    Wheelbase 2750mm 2350mm
    Front Track 1689mm 1490mm
    Rear Track 1618mm 1548mm
    Boot Capacity 320 Litres 105 Litres
    Weight 1579kg 1585kg
    Fuel Tank 105 Litres 67 Litres
    Brakes
    Front 353mm vent'd discs 350mm vent'd discs
    Rear 327mm vent'd discs 350mm vent'd discs
    Wheels
    Front / Rear 8.5J X 19in / 11J X 20in 8.5J X 19in / 11J X 19in
    Tyres
    Front 245 / 40 ZR19 235 / 35 ZR19
    Rear 305 / 35 ZR20 305 / 30 ZR19
    I hope all of you find them interesting. If any of you have seen these stats before sorry for the repost.
    I hope all of you find them interesting like I do?
    Thank you.
  14. Ulmis
    Ulmis Formula Junior
    Apr 16, 2005
    352
    He does like it ????? looool
    It`s the best car in it`s class and this by far , it has no competiton whatsoever .
    He does like it ???????????? looooooooool
    Ohhh and good ol` AUTOCAR test data : 0-62 in 3.9 hehe
    The car can actually do it in 3.5, but hey we are used with this kind of info provided by them , just like in the test between F430 vs M5.
    We should wait for EVO`s and Road&Track for more ACCURATE & OBJECTIVE articles
    Cheers
    He does like it ................hehehehe
  15. admcewen
    admcewen Karting
    May 3, 2005
    103
    West Suffolk
    Adam McEwen
    Those performance figures are not Autocars official figures mainly because that was not a road test but a "first drive". Also when they do test it the test wil be more accurate than the other publications mainly because Autocar invented the road test and most of the worlds car makers and publications will use Autocars figures when they have tested something.
  16. Ulmis
    Apr 16, 2005
    352
    ^^^ then who`s official figures are ?????
    Ferrari said 3.7sec for 0-100km/h, and the developer test driver said the car could easliy do it in 3.5sec.
    Also the weight released by ferrari is different
  17. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    #17 tonyh, May 19, 2006
  18. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    Weight must be a typo. Another major point is that Porsche quoted weights are always to EC standard, incl allowance for driver, fuel, luggage etc. Ferrari quotes weight of car with no fuel, no driver, no luggage, so even if the quoted weights are similar, reality is the Porsche would be around 150kg lighter.
  19. TBond8
    TBond8 Karting
    Feb 7, 2006
    136
    CT,CA, Europe
    Thomas
    I agree, I am interested to see what EVO mag test will show. I am sure that EVO will compare the 599 to the 997TT and some of the other competitors. But EVO will most likely have a compare test after they have an article just on the 599.
    For me the figures are not as important as the words Andrew wrote. How the 599 speaks to him and how he has looked at Ferraris and which cars he feels were / are special. Now his choices may not be each of ours but I always find it interesting to read how Ferraris speak to different people.
    I enjoyed the article and all it does is make me interested in reading articles by others as we move forward.
    I also do like the pictures that Autocar took of the 599. I admit some of them are not terrific pictures, but they are nice. The 599 is really growing on me.
    Thank you.
  20. dreamcatcher
    dreamcatcher Karting
    Feb 25, 2006
    203
    Switzerland
    could someone share the article on a online base; because in switzerland I can`t find the autocar magazin
    I heard the sound of black 599 on a show, its amazing, and the car is much more beautiful in live then on every picture that I saw.
    I changed my order from a 430 to a 599 because the small pricedifference speaks for the 599, a fully loaded 430 is approx. 40 K USD cheaper then a 599
  21. maranello71
    maranello71 Formula 3
    Jan 23, 2004
    1,221
    Chicagoland
    Andre
    I live in Switzerland too. What is the retail price of a 599? How can it be only 50'000 Sfr. more than an F430? Surely that's for a "bone stock" 599 compared to a "full monty" F430 (with ceramic brakes, etc.). How much is the difference if you compare a fully equipped 599? Surely it must be a lot more, otherwise it'll send F430 sales nosediving and destroy its residuals...
  22. dreamcatcher
    Feb 25, 2006
    203
    Switzerland
    its a mix of options thats rigth, but on the other hand the price of 599 now is much more sapid for me thats the point from my side.
    Do you think on the other way around
  23. maranello71
    Jan 23, 2004
    1,221
    Chicagoland
    Andre
    Don't know what I would choose, if money was no object the 599 is going to be far more exclusive and I'm sure that it will handle as well as an F430 on top of being much faster in the straights. On the other hand, the F430 offers an unique combination of mid-engined design, lightweight construction and razor-sharp reactivity that make it one of the most entertaining drivers' cars in the world. Ideally I'd like to have both in the garage!
    However, since for me money IS an important part of the equation, I would say that probably a new F430 will have a better medium-term depreciation. I expect that if I order an F430 for 240K today it will be worth at least 169K if I sell it in 2-3 years time. I think like all previous 12-cylinders the 599 will suffer more in the beginning: in 2-3 years time a 300K F599 will be worh 190-200K at best, so the loss will be much larger. If you plan to keep your car more than 5 years I think they will both converge and settle between 120 and 150K depending on mileage/color/trim/condition. I give these figures based on examining the Swiss market in the last 5 years.
  24. TBond8
    TBond8 Karting
    Feb 7, 2006
    136
    CT,CA, Europe
    Thomas
    I think the two of you have touched on the real difference between the 599 and the F430. Both are brillant cars. Designed for a different feel. One mid-engined kind of racer sports car and the other more GT. I agree money no object I would love to have the in my garage. But in real world choosing one vs the other is not as easy. I am not sure which one I would choose if both were easily available.
    I will say I can't wait to see the 599 in person.
