AutoX Wheel / Tire Recommendation for 308? | FerrariChat
Discussion in '308/328' started by cray54, Dec 15, 2005.
  1. cray54
    cray54 Karting
    Nov 4, 2005
    184
    Ashfield, MA
    Christopher Gray
    I have been doing repeated searches and am having a hard time finding suggestions for wheel / tire combinations for autocrossing a 308 [GT4, but any 308 info would be helpful].
    I have a set of 16x7 and 16x8 Speedline wheels w/ Yokohama AVS S1 tires (205x55R16 fronts and 225x50R16 rears) on the car now with a little life left, and also have a set of original 14x7.5 wheels. Would either of these wheel sets be ideal? Or should I be looking for a different setup with or without staggered widths? I want to leave one set on the car for the road, and have another set for autox / track.
    I’ve found oftentimes when dealing with Datsuns that people stay down at 14”-15” rims for autocrossing, and in the 15”-17” range for the street… I did not know if this practice carried over to cars with dual wishbone suspensions or not.
    Thanks!
    -Chris
  2. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    Steven R. tracks the hell out of his 308. Not sure if he also does 'crossing. I'm sure he'll chime in as soon as he sees the post.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    I found, even when I had a stock engine that I needed more tire in back than in front. So I would recomend the 16s. You may want to spend some time looking at available tires sizes, that may help you decide.
    I'm running 18x8.5 with 225/40 tires in the front and 18x10.5 with 285/35 tires in the rear.
    The other thing that makes a big difference is the springs. Autocross loves heasvy springs, I run Emod or SM2 (because my engine is modified) so it's allowed in my classes. I use 450lb/in F and 400 rear.
  4. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    Hey Mark, any pics?
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    Your wheel sets basically represent "OEM Early" version, and then the later 308/328 went to the "OEM later" set you have, with wider rears......
    No idea on the autocross scene........
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    #6 mk e, Dec 15, 2005
  7. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    are those 360s?
  8. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    If you're serious about auto X, you may cosider buying another car before sinking too much in the Ferrari. 308's are too heavy for the parking lot circuits to be competative with what shows up. You're thinking ASP I take it?
    Ken
  9. cray54
    cray54 Karting
    Nov 4, 2005
    184
    Ashfield, MA
    Christopher Gray
    I am planning on doing both parking lot events and track events on a reasonably frequent basis, but just for the fun of it.
    -Chris
  10. Imola2001
    Imola2001 Formula Junior
    Jul 17, 2005
    889
    SoCO & SoCal
    Mike C.
    Not sure how much you drive your car during the year, and if you have street tires currently on the 14" wheels, but I would use those for "street" if needed.
    For the 16" wheels you could get the "new" DOT legal compt tire from Yokohama, their ADVAN A048 in the 205-55-16 & 225-50-16 sizes.
    You can get them in "medium" or "medium hard" compounds. Medium will get you bit better time in the autoX, but wear out a bit faster.
    I had their A032R tires on a few of my cars that I drove on daily, and would get @8,000 miles out of a set before needing replacement. If you drove your car @3,000 miles a year, I could see you not having to swap wheels, and simply buying a new set of tires every couple years.
    More info about these tires is at www.tirerack.com
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    They're 550
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    I've won events in both Emod and SM2 with my 308, it does quite well.
  13. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    I take it you're not running a very stock setup; what kind of HP are you getting? I was talking about ASP, the "beginner" circuit. It caters to lower power but light cars. 308's are dogs because the straights are too short and they don't turn or accelerate as well as a WRX, Miata, and yes, a Europa. I don't race but lots of my brethern do.
    Ken
  14. BigTex
    79,386
    Houston, Texas
    Bubba
    Mike's supercharger bumps 700 ponies.........:rolleyes:
  15. BigTex
    79,386
    Houston, Texas
    Bubba
    Well, maybe not THAT many.........LOL!
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    It's 420 at the wheels, so 500+ crank.
    You're right, there are other car that are probably better suited, but honestly the point is to go have fun, at least to me it is. I have a ball beating the snot out of the ferrari....but them I used to insist on roadracing a harely too.
  17. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Chris, i track the living ^%$^* out of the car here. AutoX and track are DIFFERENT beasts. Frankly, AutoX is probably best in a lightweight package. Have never done it, but have watched a few and the movement is VERY unnatural and yes, you WILL need to up the springs/shocks for AutoX if you insist on AutoX.
    As for track, am still learning and have made the occasional mistakes as time has gone by. We had 300 lbs front and 250 lbs rears with Fchat sponsor Nick Forza dual-adjustable shocks and stock sway bars.
    Blew out a shock and after some consideration and experience i realized we need stronger springs and NOT turn up the shock setting so high. We are installing 400 front and 350 rear springs (FYI: stock is 178 front and 187 rear for a late model GTS). We are also going with adjustable http://www.sanerperffab.com/ sway bars and remember to get his split collars.
    So the deal is even if you AutoX, you have adjustable shocks and adjustable sways. Naturally you want to lower the car to lower the CG and DUMP as much weight out of the car as you can (lighter seats, remove AC, etc). Also, redo all your suspension bushings with Energy Suspension 'G' polys.
    Other tweaks include going with Fchat sponsor Girodisc brakes to lower sprung weight and lower the chance of brake fade due to heat. Have seen a stock 308 at the track and the stock brakes COOKED within a few laps, the calipers locked up and resulted in major flat spotting of the tire as the brake discs AND calipers were at about 550F and you could SEE the bearing grease BOILING out of the hub! Fortunately no damage to the car other than a flat spotted tire... but the consequences of brake fade could be deadly (literally). Naturally you will want to use Motul 600 brake fluid and REMOVE the metal brake disc covers on the inside of the front rotors, as removing them aids in brake cooling. Remember to install Goodridge steel braided brake lines.
    There are others here with LOTS more info and track time then me, though the above are some basics.
    To answer your original question, i use Kinesis K27 rims size 17x8 and 17x9 and use Mich Pilot Sport PS2 as the car here is also a daily driver rain or shine. Would LOVE to buy another set of rims and use dedicated R-compound tires and am debating doing just that as a holiday gift to me :)
    Problem with that is... it also means i need to buy a lightweight aluminum car trailer to haul the car and bits to the track (or just strap the R-compound tires and rims to the roof between the rear off and in front of the top rear black aero).
    If i was a rich man....
    Are you REALLY SURE you want to AutoX and track the car? This way leads to the Dark Side of the Schwartz. Open wallet.... BIG...
    Oh, and when you discover the brake pedal goes too deep you will want to change the MC or brake setup to increase pressure and reduce pedal movement.
    Did i mention the 4/5-way harness you will want and lightweight race seats?
    Brake pads...
    OK, i'll stop. Please use the SEARCH function and see what others have done. There is more than one way to skin the proverbial cat, but virtually none of them is Ricer Drop In Parts easy and cheap.
    You could sell the 308 and get a used Lotus or Mini S and hop them up.
    Ever consider go-kart racing? Cheap thrills and fast n fun! Formula Atlantic is fun...
    Ok, i'll stop. Really, i swear i am. Stop. Stop it Steven...
    Ok, one last thought.
    www.ispexperts.com/nhis090105a.wmv
    www.ispexperts.com/nhis308large.wmv
    That's me.
    Hi, my name is Steve and i am NOT a recovering track junkie...
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    Steve,
    Part of the beauty of autoX is it happens about about 60 mph and is over in 60 seconds. At that speed/time, the brakes and bearing or anything els don't overheat, no extra seat belts or roll bar or anything else are required for safety and a set of race tires lasts 2 or 3 seasons. Make a huge mistake and you knock down a few cones, which I can tell you from experience buff out much better than the scuff that come from gravel traps and guardrails.
    It's really hard to hurt the car, yourself, or oyur wallet at an autox...which is why that is the only game I play these days.
  19. cray54
    cray54 Karting
    Nov 4, 2005
    184
    Ashfield, MA
    Christopher Gray
    #19 cray54, Dec 15, 2005
    Thank you guys for your thoughts and input. Believe me, I have been searching ... and reading.. and searching... and not working... but I had not yet found anything about wheel / tire sizes for autox or track. I just purchased the car and have been doing as much research as possible… and I’m not ready to sell it just yet :). I’m going to be using it primarily as a driver, and for fun at autox events and an open track event here and there.
    I agree that a small nimble car will do better in an autox event than others, however, I feel the purpose of an autox event for me (and the club I’ve participated in for about 6 years now) is to learn how to stretch your car and learn its limits at speeds you will see every day. That being said, the car I autox now is a 2900lb RWD ’84 Nissan Maxima Turbo. I wont ever see a winners circle, but I know exactly what my brick on wheels will do on the road. I hope to learn as best as possible what my 308 GT4 can do in a parking lot so I don’t push it past its limit elsewhere.
    Thank you very much for the suspension info! I’m going to take the car out stock (except for wheels and tires) in the spring before doing any upgrades so I can judge what needs to be done and afterward judge if things were improved or not. I’ve only been to one track event with a stock 280Z and it was a blast. I’m hoping to get this car to a couple after I get a feel for how it behaves.
    I think I like the idea Imola2001 presented using the 16” rims I have for daily driving with competition tires. I’ll have to do a bit more research on that particular tire but that seems like the smartest move at this point.
    enjoythemusic… the first car I saw on this forum was yours and I searched for all posts by you to see any other pictures I could find and saved them to my drive. It is one awesome 308.
    -Chris
  20. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    (Said in good humor) Wow, that sounds familiar. Hit me a little too close to home huh? ;-)
    True, the brakes are no biggie, but i recall he did mention track time. Yup, he said "I am planning on doing both parking lot events and track events on a reasonably frequent basis, but just for the fun of it."
    Ok, so he needs not go all out as myself and a few others here. i guess basics would be to lose AS MUCH weight as possible, get steel braided brake lines, use Motul 600, and remove the front brake rotor guards in hopes of keeping them cool at a track.
    Oh... don't remind me. When my mechanic looked at the car a bit ago for the winter storage/upgrades he asked WTF have i been doing. When Fchatter Verell visualizes the condition of my old Euro front aero (i am giving it to him as we are replacing it) he is gonna flip at the crap that poor piece has been through. Umm.. you forgot to mention tire walls :(
    Ahhh i c. Cool. Dunno though, i find AutoX ok and all, and yes it takes skill... but a road course race track (for me) is like a what i see on TV when someone gets a shot of crack Peruvian Marching Powder.
  21. cray54
    cray54 Karting
    Nov 4, 2005
    184
    Ashfield, MA
    Christopher Gray
    Hay Steve,
    I do appreciate you covering all of the things I was asking about. SS brake lines are were on my list of things to do eventually, but after hearing it suggested I'll bump that to the top of the list with flushing and replacing the brake fluid (was looking at nick forza's lines, but have not had a chance to research further).
    My next step is going to be installing, routing, and testing brake ducts and their ability to reduce fade on the stock setup.
    As for weight, the car has fiberglass bumpers, and upgraded exhaust (supposedly lighter) currently... and I'm going to wait until I get back to Chicago where my scales are before pulling much else off.
    -Chris
