Auxiliary Air Valve | FerrariChat
Auxiliary Air Valve
Discussion in '308/328' started by Gino328, Jan 28, 2021.
  1. Gino328
    Gino328 Rookie
    Jun 21, 2020
    17
    Joe Watson
    I know there have been a lot of prior threads on the auxiliary air valve for a 328GTS, but frankly the information is confusing. Does anyone know how or where this part can be obtained? Are new ones still being made?
  2. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    Search Bosch
    0280140104
    On internet.
  3. Steve Magnusson
    26,839
    #3 Steve Magnusson, Jan 28, 2021
    The Bosch Application Data for Ferrari that I have indicates the AAV for a 328 is 0280140229 -- this style/shape for mounting to a coolant expansion tank that seems to have a bigger, more rectangular heat sink body:
    And matches the drawing of the 328 AAV in the 328 SPC:
    (I believe the 0280140104 AAV is used on some F models where the AAV is mounted on top of the engine.)
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    waymar likes this.
  5. Gino328
    Gino328 Rookie
    Jun 21, 2020
    17
    Joe Watson
    Thanks Steve. Your diagram and part number are correct, but no one seems to have the part. Do you know of any sources? They come up on Ebay from time to time but most look really banged up.
  6. Steve Magnusson
    26,839
    No, unfortunately, I don't. I believe Bosch has gotten a little better lately about supplying old CIS parts (like fuel distributors), but to quote Rifledriver from a few years ago about actually getting information from Bosch "good luck with that" ;) Good Hunting!
    PS Are you confirming that the Bosch PN shown on your old AAV that you know is from a 328 is 0280140229?
    PPS I've also seen the 0280140209 AAV that has the same overall shape. Don't know the spec differences, but it may be more available if desparate.
  7. Gino328
    Gino328 Rookie
    Jun 21, 2020
    17
    Joe Watson
    I will confirm the Bosch part number once the AAV is removed next week.
  8. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Porsche 928s 1978-1981 also use the same design but would need to check part numbers.
  9. BLACK HORSE
    BLACK HORSE Formula 3
    1,966
    California - Bay Area
    Rob
    I just had mine professionally rebuilt
  10. Steve Magnusson
    26,839
    By whom?
  11. BLACK HORSE
    1,966
    Rob
    BigTex likes this.
  12. paul01
    paul01 Karting
    Jul 31, 2011
    104
  13. lopena
    lopena Formula Junior
    759
    Gino:
    Give Larry Fletcher at CIS Flow Tech a call (251-929-3771) or drop him an email ([email protected]).
    He has encyclopedic knowledge of 1970-1980’s Ferraris and K-Jetronic systems in particular. He’ll help you diagnose your problems over the phone. His company (in Fairhope, Alabama) rebuilds AAV’s, warm-up regulators, fuel distributors etc.
    He’s a great resource to the Ferrari community.
    good luck,
    Alan
    N.J.
  14. Gino328
    Gino328 Rookie
    Jun 21, 2020
    17
    Joe Watson
    Yes - the Bosch part number on the OEM 328 AAV is 0280140229.
  15. Steve Magnusson
    26,839
    Thanks for confirming the Bosch PN.
  16. lopena
    759
    I checked with the ebay vendor referenced above and he told me that the Bosch part number on his AAV was # 0 280 140 217. The AAV on a 328 is Bosch # 0 280 140 229.
    Now, that’s not to say that the ebay unit won’t work just fine on a 328, but there is a difference between the units...perhaps the temperature or speed at which the valve opens and closes...this would affect how fast and how long the car fast-idles when cold.
    So, has anyone out there actually used one of these alternative AAV’s on their 328? There are several variants that all have the same shape and dimensions.
    Alan
    N.J.
  17. paul01
    paul01 Karting
    Jul 31, 2011
    104
    Alan,
    "There are several variants that all have the same shape and dimensions" -> yes. For several cars incl. Lamborghini.
    Paul
  18. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    391
    Herts, UK
    Richard
    The physical size is the same.
    Here are the operating characteristic's.
    Closes between 60-70 deg C water temp. Coil resistance 30-40 ohms.
    The above is from my Range Rover workshop manual.
    Can anyone chip in with the operating spec for a 328?
    race27 likes this.
  19. QV308
    QV308 Karting
    Jan 1, 2006
    106
    Germany
    Ross
    I'm a bit late to this thread so hope this is still required. The Bosch AAV p/n 0 280 140 229 spec is:
    Air volume = 34 m³/h
    Heating coil resistance = 21 Ohms
    The Ferrari version was more or less identical to the AAV used on the Porsche 911 SC (US variant) from 1980 - p/n 0 280 140 218 (but this Porsche version was published as only officially available until 1990).
    Steve Magnusson likes this.
  20. QV308
    QV308 Karting
    Jan 1, 2006
    106
    Germany
    Ross
    The 0 280 140 217 is a bit different in its spec. Heating coil has a higher resistance (33 ohms vs. 21 ohms) and air volume is lower (14 m³/h vs. 34 m³/h).
  21. lopena
    759
    Wow...that’s quite a difference in air volumes.
    So the 217 unit wouldn’t increase the cold-idle rpm’s very much when compared to the 229.
    The higher resistance of the 217 tells me that there are more internal heating-element windings, meaning a shorter warm-up cycle.
    Bottom line: the 217 may fit a 328 but it won’t provide a proper warm-up compared to a 229.
    Alan
    N.J.
