Auxillary Heater Water Pump Connector | FerrariChat
Discussion in '348/355' started by 348Jeff, Oct 2, 2014.
  1. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #1 348Jeff, Oct 2, 2014
    Hi folks - my 348 HVAC was throwing an E8 error so decided to replace the auxillary water pum with what I believe is the modern equivalent.
    After a search of the parts alternative thread I ordered a Bosch 0392020039 which looks almost identical but with one (important) difference. Rather than 2 wires out the base of the motor it as a socket at the top which I'm ok with but just wondering what the correct plug is so I can buy a proper one and wire something up so it all looks factory etc
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
  3. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #3 348Jeff, Oct 2, 2014
    I have actually ordered something like that but not 100% sure its right as it didnt specify a size???? (ive got male and female as I want to do the other end of the wire too)
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #4 348Jeff, Oct 6, 2014
  5. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Post the picture and part number in the cross reference thread. This is a great find.
  6. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    The Bosch part no is already in the cross ref thread and theres no part no for the connectors - its just a description of the connector type
  7. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Well, post the diverter valve part number as close replacement...
  8. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    The diverter valve is a different part - this is the auxiliary water pump to keep flow going through the heater when the car is idle
  9. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #9 348Jeff, Oct 11, 2014
    Decided to recycle the existing lead so out with the snippers
    I removed the outer sheath, stripped the ends of the wires with my stripper then put the sheath back on and then tinned the ends of the wires to make the crimping easier.
    After rechecking the terminals on the pump (they're marked + and - just on the plug socket) I plugged each newly crimped wire into the junior power housing until it clicked home. Hopefully I've ended up with something that looks reasonably factory.
    Just about doesn't stand too high up - I'e checked with bonnet shut and it doesn't appear to interfere in any way but if it does there's room for a bit of adjustment to lower the pump further.
    No more E8 error :) I've switched the ignition on and you can hear/feel the motor whirring. Just need some dry weather now so I can take the car out for a decent run and see if the heating in the cabin has improved which I'm quite hopeful of!.
    Just as a note you can buy a pump from eurospares which is around £200 + but TBH I think what they are supplying is the above pump so quite a saving to be made (Ricambi in US also show an identical pump on their website).
  10. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Nice job and great info. Thanks for sharing!
  11. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Qavion likes this.
