Average Life of an O2 sensor | FerrariChat
Discussion in 'Technical Q&A' started by ants2au, May 9, 2004.
  1. ants2au
    ants2au Formula Junior
    Nov 19, 2003
    812
    Sydney Australia
    Anthony
    Does anyone have any data on the average life of an O2 sensor?
    Is it an item that is replaced during a XXKm service usually?
    if so, what is that interval?
  2. tbakowsky
    Sep 18, 2002
    20,027
    The Cold North
    Tom
    Around 60,000 Km is the usual life expectency of an o2 sensor. But they have been knowen to give false readings before this time(many time really) It has now gotten to the point with newer cars, that with every tune up an o2 sensor is a recommended part to change.
  3. DGS
    DGS Seven Time F1 World Champ
    72,867
    MidTN
    DGS
    O2 sensors don't give a static reading, but have outputs that oscillate. As the sensor gets old, the period of oscillation increases. The latest generation of ECUs will detect the long cycle time and set an appropriate internal code (and light the "check engine" lamp).
    It takes a while for an O2 sensor to age out, but there are any number of contaminants that will seriously mess up an O2 sensor, regardless of age, causing odd readings. There are several types of O2 sensors, and they tend to be part of the modern ECU's "closed" control loop, so diagnosing problems can be a bit technical for a mechanic that doesn't have an electronics degree.
    It's a lot easier to just replace it periodically, "just in case".
  4. ants2au
    Nov 19, 2003
    812
    Sydney Australia
    Anthony
    I have one of those. Doesn't seem to be helping at the moment :)
    Seriously, I may put the scope on it and see what is hapenning.
    It's a lot easier to just replace it periodically, "just in case".[/QUOTE]
  5. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    The 550 service manual says to replace at 60,000km.
    Many have been changed much earlier, for good reason.
  6. Dr Tommy Cosgrove
    36,578
    Birmingham, AL
    Tommy
    Does leaded gas hurt them?
  7. DGS
    72,867
    MidTN
    DGS
  8. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    Does running at WOT for hours at a time hurt them or clean them off?
