458 - AVH, ESC, ABS, Manettino Errors | FerrariChat
458 AVH, ESC, ABS, Manettino Errors
Discussion in '458 Italia/488/F8' started by hgoodwiniii, Mar 2, 2025.
  1. hgoodwiniii
    hgoodwiniii Formula Junior
    279
    Hi everyone, I'm getting the dreaded rolling AVH, ESC, ABS, Manettino error messages. I've seen a few threads discussing this but not really sure I've seen a resolution.
    Here are the facts: I somehow forgot to put my car on the trickle charger for a while and the battery completely drained. I had to jump charge it from a different vehicle to move it and drove it a bit without fully charging it. It's has been fully charged and on the trickle ever since.
    Ever since this all happened, I have been getting the AVH, ESC, ABS, Manettino error messages. The car drives fine and all of a sudden the errors appear. They go away once the car is shut off, sits for a while and is restarted but they constantly come back. It's driving me nuts.
    I have done the factory reset procedure and the errors continue to come back. My battery is probably 1.5 years old.
    Any ideas/suggestions on what I need to check/do now? Thanks.
  2. hex337
    hex337 Rookie
    May 20, 2024
    47
    Alex Kleissner
    I had this on my 458. Does it revert to wet mode when this happens?
    At first the dealer thought it was maybe bad wiring, and did a few fixes, but that didn't fix it. The failures really only happened when the car went over a bump or gravel, and we ended up figuring out that it was a faulty traction sensor. Not sure if that's what you have, but I would get an error code reader and see if you can connect it when the errors happen to narrow down the issue (this is what helped me, just kept the reader in the car waiting for the issue to happen and then plugged it in).
    Good luck, and hopefully it's an easy fix (might also want to put which model you have in the title).
  3. hgoodwiniii
    279
    Thanks for the feedback. Mine has reverted to wet mode a few times it has happened. Thanks. I will get a code reader and see if I can nail it down. My apologies -I was so frustrated when I posted. My car is a 2011 458 Italia. No sure I can change the title at this point.
  4. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,271
    AUSTRALIA
    ANGELO
    Solution :
    By new battery and get Ferrari dealer to get rid of the codes. Full Stop.
    Prevent happening again:
    Always keep on battery conditioner.
    Age of battery has nothing to do with it, its the condition of the battery that is important.
    To jump start most likely a cell or 2 are stuffed.
    hgoodwiniii likes this.
  5. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Alexandros Siregos
    #5 Ferdi, Mar 3, 2025
    Hi hgoodwiniii
    Had exactly the same problem one week ago.... it's not the battery like many Ferrari workshops think.
    It's an easy fix... change the brake light switch on the brake pedal and all the problems will be gone like magic :D
    You have to remove two screws, then turn the switch about 90 dergrees pull it out and insert the new one. It's a
    15 minute job and it'l cost you about 50$
    Thnx to #Fv81587
    Parts needed :
    Part number : 201957
    PUSH-BUTTON SWITCH
    The part needed is number 14
    mdrums likes this.
  6. hgoodwiniii
    279
    Thanks for the feedback; I will pull the battery and have it tested to eliminate that it as the problem for peace of mind and I will certainly look into the brake switch. Thanks.
  7. cwazy1
    cwazy1 Rookie
    Jul 5, 2024
    42
    WA
    This. Do not start replacing parts immediately. That error will come back if its not cleared. Get a lithium battery, clear the codes, check again. Only once you've ruled out battery start replacing other stuff. To be completely transparent. Mine was still acting up with a brand new battery. The voltage sensitivity was still too much and triggering false positives.
  8. triblk6spd
    triblk6spd Rookie
    22
    Austin, TX
    JT
    My car is fine however reading this post makes me wonder how you came to find the brake switch as a solution to your issues??
  9. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Alexandros Siregos
    Because all this systems need the information from the brake switch, to put it simply and not to describe it in a too complex way.
    I hade exactly the same issues and the fault code on the diagnosis was, among all other unimportant faults, the brake light switch.
    Then to be on the safe side, I searched here and found another thread with exactly this issue.
    triblk6spd likes this.
  10. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    Can you post a link to the other thread you found?
  11. v35
    v35 Karting
    May 15, 2013
    222
    Los Angeles
    Aaron
  12. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Alexandros Siregos
    triblk6spd and hgoodwiniii like this.
  13. Drl22
    Drl22 Rookie
    Dec 27, 2020
    4
    I have had this problem and it seems it is the ABS module electronics that are faulty. I went through all the usual suspects, ABS sensors, brake switch, new battery etc. Even had all the wiring checked and everything was as it should be. I’ll get it back in a few days and fingers crossed this is the issue because after that I’m stumped.
  14. hgoodwiniii
    279
    Ok, thanks. I am going to look more into mine today.
  15. hgoodwiniii
    279
    Here are some DTC codes from my car:
    P1569 Cruise Control/Brake Switch B Circuit (Bank 2) - Malfunction (Plaus)
    P0571 Brake Signal Invalid Signal
    P0572 Brake Signal Too Low
    C1161 Brake Light Switch Invalid Signal
    I'm thinking my rolling AVH, ESC, ABS, Manettino error messages may be due to the brake switch. I will change it and report back.
    flash32 likes this.
  16. hgoodwiniii
    279
    I changed the brake switch in my car and have put about 100 miles on my car and so far the rolling AVH, ESC, ABS, Manettino error messages have not reappeared. So far, so good!
    dgl36 likes this.
  17. Arwyn
    Arwyn Rookie
    Feb 27, 2025
    24
    Dallas
    Michael Dunne
    Guys, thank you!!!
    Just got my 458, and got this exact issue showing up. I was panicking, but the symptoms you guys listed were exactly what I was seeing. If this is the issue, you just saved me a ulcer!
