AVH, ESC, ABS, Manettino failure | FerrariChat
Discussion in 'California/Portofino/Roma' started by richkh, Nov 29, 2023.
  1. richkh
    richkh Rookie
    Jul 25, 2023
    30
    R H
    Hello,
    When I was out driving at the weekend I got all the error system failure messages on my dashboard. I have done a battery reset and replaced the brake switch but to no avail. Battery is new and always on tender when not in use.
    Does anyone know what might have gone wrong? I imagine it is a sensor.
  2. vjd3
    vjd3 F1 Rookie
    2,707
    Massachusetts
    Vic
    If you do not wait the 5-10 seconds or so after switching on the ignition for the three beeps signifying the car is ready to be started before you hit the start button, you can get those errors ... if it's doing it constantly, might need to take it to the dealer or independent and have them check the codes.
    sherrillt likes this.
  3. richkh
    richkh Rookie
    Jul 25, 2023
    30
    R H
    The warnings appear after the check lights go out.
    I’ve got it booked in with a dealer. I’ve got to get it transported there as the car goes into limp mode.
  4. dera
    dera Formula Junior
    Oct 7, 2023
    334
    Charlotte, NC
    Mikko
    What car is it?
  5. richkh
    richkh Rookie
    Jul 25, 2023
    30
    R H
    California 30
  6. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    Had this once and it was an EVAP issue IIRC. If you Google...
    site:ferrarichat.com Ferrari California EVAP issue
    you can see some other similar issues that may be helpful. In my case, it was a loose gas cap.
    Best,
    T
  7. richkh
    richkh Rookie
    Jul 25, 2023
    30
    R H
    Hi, thanks for your message. It happened after I filled up with fuel so could it be I didn’t put it on correctly and it is loose?
  8. tomc
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    It could be. I was lucky.
    I hope it works out for you as well.
    T
    p.s. If you haven't post up some pics of your 30.
    richkh likes this.
  9. richkh
    richkh Rookie
    Jul 25, 2023
    30
    R H
    My car is at the dealer so I’ll find out next week what the problem is. The car coincidentally needs a new rear wheel bearing and rear quarter window as the seal has perished.
    Here are some pictures of my car…
    https://www.instagram.com/p/CzmWfYzMK0i/?igshid=MzRlODBiNWFlZA==
    tomc likes this.
  10. tomc
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    Nice. Love that 2nd picture in the sequence. Great looking stance.
    T
    richkh likes this.
  11. richkh
    richkh Rookie
    Jul 25, 2023
    30
    R H
    Apologies, I forgot to update this thread. The issue was battery low voltage. Dealer cleared all the error codes and with battery recharge all is ok. It is a bit odd as the battery is only a couple of months old from Ferrari! Note to self put battery on tender regardless on how much I use it.
  12. tomc
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    Ferrari batteries are notoriously sketchy. Even the new ones, I fear. Glad it was so simple.
    T
    richkh likes this.
