awesome Bugatti Atlantic model by CMC | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by CollectorMorry, Apr 18, 2011.
  1. CollectorMorry
    CollectorMorry Formula 3
    Nov 5, 2003
    2,014
    Toronto, ON, Canada
    Morry Barmak
    #1 CollectorMorry, Apr 18, 2011
    Finally it’s here – the ultimate Bugatti model. CMC has just released the 1938 Bugatti Type 57SC Atlantic Coupe. This incredible 9” long diecast model is made from around 1700 parts. Only 5000 are being made. If you collect Bugatti memorabilia or high end models, this one is a ‘must have’. This masterpiece is available for just $339.95 / £215 / €240 + shipping.
    Here are some details:
    -The radiator grille is finely meshed. The metal pins support the open engine hood wings. The wheels are appareled with aluminium rims and stainless steel spokes. Every single stainless steel spoke is equipped with a single nipple.
    -Elegant door design with three hinges and a fully functional guidance bar sliding mechanism. The seats and as well the door interior, which is sewn with functional pockets, is covered with real leather
    -Finely recreated cockpit. The dashboard looks true to the original with all instruments and control elements
    -The perfectly shaped radiator grille of metal with Bugatti emblem is chromed with a high gloss finish. The number plate equates the original as well.
    -The spare wheel in the rear end hutch can be taken out. The gas cap and as well the cap of the cooler is removable, too.
    -The double-winged engine hood is hinged on both sides. The highly detailed 8-cylinder in-line-engine includes all aggregates and cabling
    -The underbody is a high-end recreation of the original. The underbody plate, which is equipped with air vents, is made of metal. The exhaust pipe system is made of stainless steel. The frame is also a solid metal construction.
    http://www.collectorstudio.com/index.cfm/ID/18/itemID/4421/details/1?cl=
    Kindly let me know if you are interested.
    Regards,
    Morry Barmak
    COLLECTOR STUDIO - Motorsport Gallery
    136 Yorkville Ave.
    Toronto, ON, M5R 1C2, Canada
    tel/fax: 416.975.5442
  2. CollectorMorry
    Nov 5, 2003
    2,014
    Toronto, ON, Canada
    Morry Barmak
    This model has been flying....let me know if you you still want one while I have stock left.....thanks for the FChat orders received so far!
