348 - Axle stuck in hub - help | FerrariChat
348 Axle stuck in hub - help
Discussion in '348/355' started by dahveedem, Mar 17, 2024.
  1. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Trying to replace my inner cv boot (gonna do outer as well).
    Read all the posts and surprisingly the inner connector on the axle wasn't as hard as they said.
    My issue is I can't get the darn axle out of the hub.
    Here's what I've tried.
    Pb blaster, small sledge hammer, big sledge hammer, jaws, slide hammer and heat with all of them.
    Won't budge.
    I can't find any nuts or bolts on back of hub that would keep it in place.
    I'm stuck - ideas.
  2. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Shot of it.
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  4. fatbillybob
    Aug 10, 2002
    28,828
    socal
    put a 3 prong puller on it. the hole in the middle of the shaft is an orientation hole to hold the tip of a puller from slipping off. The apply good pressure. Those splined shafts don't need much pressure. Make sure that suspension in droop is not pinching the axle shaft locking it in place. remove the inner end of axle shaft so it is free and unable to absorb the pressure from pulller. If it will not budge then you are never going to get heat in the right place to expand contract for movement. Put the puller on and put good pressure but do not break tool. Use wd40 or pb blaster at the spline shaft and then heat the shaft to draw oil into the splines to loosen corrosion. This will cause flames so keep a water spray bottle handy. Rinse and repeat trying to draw the wd40 into the splines. That should loosen it up so you can drive the shaft.
    LondonParis likes this.
  5. fatbillybob
    Aug 10, 2002
    28,828
    socal
    That's because you are assembly # <8798
  6. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Just trying to replace the CV boots. To do that I need to get the axle out of the car.
    I tried the 3 prong and heat.
    It simply will not budge. So I took the while hub out with the axle. Standing it up and soaking it with pb blaster.
    Will try adding heat to it in this position.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  8. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    #8 dahveedem, Mar 17, 2024
    Interesting. I do see 4 bolts on the back of the hub to get me to the wheel bearing.
    The problem is I can't get the axle shaft to move. Every other axle I've done has been like others have said.. either a light finger push or maybe a light hammer.
  9. fatbillybob
    Aug 10, 2002
    28,828
    socal
    Amazing you can't get that off. I have never seen one frozen on any car I could not get off with hammer or puller. I guess rust??? The article above Ian even pushes the shaft with hands to move shaft to get access to the hub nuts. I'm heating and drawing pb in there rinse and repeat. Then in that nice position I'm putting a sacrifice hut on the end of the shaft to protect it supporting the assembly in a fixture and wack it hard with the BFH.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,469
    San Carlos, CA
    Mitchell Le
    You need a bigger puller than that.
  11. yelcab
    Nov 29, 2001
    13,469
    San Carlos, CA
    Mitchell Le
  12. audi_328
    audi_328 F1 Rookie
    2,772
    NH
    Audi
    I spent 2 days and wrecked a couple screw-type 3-jaw pullers trying to do this same job on a BMW (12 year old car, daily driver in the northeast, splines didn't look rusted but there must have been some corrosion). You guys that have only had to tap it out with a rubber mallet don't know what you're missing.
    Anyway, picked one of these up and it did the trick.
    https://www.harborfreight.com/10-ton-3-jaw-hydraulic-gear-puller-64982.html
  13. m.stojanovic
    m.stojanovic F1 Rookie
    3,196
    Serbia - Niš
    Miroljub Stojanovic
    Jaguar (for their X308 models at least) specifies use of Loctite 270 (red) on the shaft splines and the thread. Perhaps someone put red loctite on the splines?
  14. yelcab
    Nov 29, 2001
    13,469
    San Carlos, CA
    Mitchell Le
    no loctite in there, just simple corrosion. I had to buy that huge puller for an E30 M3 axle, and I needed a 1/2 impact driver to work the big screw. I have used it on a couple of other jobs since then and every time I needed it, that puller delivered.
    Buy a bigger puller.
    JL350 and audi_328 like this.
  15. Aerosurfer
    Aerosurfer Formula 3
    1,856
    Indianapolis
    Nick
    Had to really put the beans to it on one side of my 456 with all of the above suggestions and an increasingly large puller.
    Found a small amount of corrosion on a few splines... it was surprisingly small that was causing the bind. Cleaned, sanded and smoothed what i could and a smear of grease on the reassembly
  16. whyte
    whyte Formula Junior
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    Not my 348, but had a nightmare job on my Ford doing this. Broke several pullers, and it laughed at my torch. I ended up building a tool to push the hub out, similar to what Yelcab posted. I don't have a picture, but it essentially was a big screw and nut I put behind the hub, then torqued it down to push against the part of the assembly. Pushing vs pulling. I had to engage, disengage and rotate the tool at different angled so it wouldn't bind, but it did work.
    It was something like this:
  17. fatbillybob
    Aug 10, 2002
    28,828
    socal
    If you cannot find a puller make one. I would make from 1/4" Plate like a box with 3 sides. Drill hole in middle side weld like 22mm 12.9 nut. Use bolt to drive that shaft out using impactgun. Hub has holes so use those to stabilize the rig
  18. yelcab
    Nov 29, 2001
    13,469
    San Carlos, CA
    Mitchell Le
    My flame wrench ... is an Oxy-Acetolene torch. That baby heats it up real hot.
  19. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Praise the baby jeebus!
    Ordered a 10T hydraulic puller but they sent me a 5T.. so I figured why not.
    Thank goodness I paid a little bit of attention in physics class (thanks Mr. Whitt) and remembered leverage.
    I got maybe 1.5 pumps and was stuck. Grabbed my jack bar and put it on and put my back into it.
    A push and a reset of the pump and another push.. BANG! I thought I broke something.
    It ended up giving me 1 more BANG! And then it pretty much just fell out.
    Thanks to you guys for suggestions. Ended up not having to use any heat on it.
    I did hang it for a couple days and used PB Blaster on it.
    Now to break it down, clean it up and get it back in the car.
    Long live the 348 Brotherhood!
    David
    audi_328 and INRange like this.
  20. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Curious if anyone has run into an issue with the replacement boot kit.
    Ordered from Ricambi PN 70006021
    The outer boot is about a 1/4 inch too short to fit on the hub.
    The OG boot on the axle had PN 153 15 75 00 003.
    The one in the kit from RA had PN 153 8 75 00 002.
    See photos... the 2 boots are the new installed and the old.
    The single boot photo is the new one and part number. Which i also can't find on the Internet.
    Any ideas on this one?
  21. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    673
    Continental Europe
    How did the splines look considering how tight the assembly was? Very rusty?
  22. fdekeu
    fdekeu Formula Junior
    630
    Belzium
    Frank
    Comfy working shoes
  23. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    LOLOLOLOLOL.
    Yah.. I usually wear my black Italian loafers when I'm working on the car but my feet were cold. :)
  24. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Better than I expected - the rust wasn't the whole way through the splines. I'll grab a photo of the splines when I pick it up.
    I took it to a buddy who owns a local shop to do all the really filthy work.
  25. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
