B-17 and P-63 lost at Dallas CAF show | FerrariChat
Discussion in 'Aviation Chat' started by GrigioGuy, Nov 12, 2022.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    29,470
    E ' ' '/ F
    Trailer Swift
    Midair collision, reports and photos indicate no survivors. Video is disturbing.
  2. GrigioGuy
    Nov 26, 2001
    29,470
    E ' ' '/ F
    Trailer Swift
  3. SamuliS
    SamuliS Formula Junior
    Aug 23, 2008
    336
    Finland, Helsinki
    Samuli S
    Really sad to see. My condolences to all sides of accident. Wonder what happened in the P63
    Boomhauer likes this.
  4. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner
    Dec 1, 2000
    59,566
    Southlake, TX
    Rob Lay
    he was banked hard to left, maybe B-17 was in his blind spot "below" wings?
    Il Steeg, ChipG and Boomhauer like this.
  5. MichaelP88
    MichaelP88 Formula Junior
    Jul 22, 2022
    698
    David
    Blind spot and bad turning radius would be my guess.
    Il Steeg likes this.
  6. BJK
    BJK F1 Rookie
    Jul 18, 2014
    4,785
    CT
  7. BJK
    BJK F1 Rookie
    Jul 18, 2014
    4,785
    CT
    Ryan S. likes this.
  8. ChipG
    ChipG Formula 3
    May 26, 2011
    1,722
    Santa Monica, CA
    blind spot got him, so does this make 1 flying b-17 left?
  9. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    7,912
    Shoreline,Washington
    Robert Parks
    The P-63 has a bubble type of canopy and the view of the B-17 was above and to the left of the P-63 pilot. His turn was too tight and closing on the B-17 instead of clearing it. As far as I can determine, it was a gross maneuvering error. A B-17 is a big airplane and the P-63 pilot knew where it was. Why make a close , turning pass like that?. Inexcusable.
  10. TheMayor
    TheMayor Nine Time F1 World Champ
    98,686
    Vegas baby
    I think you're right Bob. He just made a bad turn at too high a closing speed and misjudged his flight path in the turn.
  11. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,001
    Oregon
    Gabe V.
    Hot Dog'n it killed everyone.
    And I would venture to guess the NTSB investigation will make the same call after the facts come in.
  12. TheMayor
    98,686
    Vegas baby
    If you look at this angle, I believe he didn't see the B17 at the point of impact. But he should have clearly seen it as he was approaching it. Its hard to tell but it looks like he was dropping in altitude.
  13. ArtS
    ArtS F1 Veteran
    Nov 11, 2003
    8,984
    Central NJ
    Bad day.
    RIP
    Usually a bad call results in a bit of 'pucker factor' followed by a sigh of relief then, usually, a chewing out. Unfortunately, this wasn't one of those times.
    My condolences to all involved, including the machines.
    Sincerely,
    Art S.
  14. rob lay
    Dec 1, 2000
    59,566
    Southlake, TX
    Rob Lay
    If you look at the angle he is banked left "slipping" outside into the B-17. If you drew a line from the pilots eyes to the B-17 it would be down a little forward of his feet.
    Nurburgringer likes this.
  15. ArtS
    ArtS F1 Veteran
    Nov 11, 2003
    8,984
    Central NJ
    I suspect you are right - although it would initially seem unlikely due to the canopy visibility, because of the P-63's blind spot, your explanation would be the simplest and thus the likely explanation of why the P-63 didn't make further changes in the last seconds.
    My understanding is the fighters and bombers were flying two separate patterns, which would suggest the P-63 was out of position. The P-63's pilot might have been going wide (off course) and saw the B-17, realized his mistake and pulled in tight and up to get back on course (putting the B-17 in the P-63's blind spot) the inputs weren't aggressive enough causing the P-63 to turn into the B-17 rather than avoiding. If so, a series of bad calls.
    Either way; its all speculation at this point.
  16. tazandjan
    38,038
    Truly horrible.
    rob lay and Boomhauer like this.
  17. Bob Parks
    Nov 29, 2003
    7,912
    Robert Parks
    I think that you are correct , Rob. At first it appeared to me that the P-63 hit the lower fuselage but after exercising some pauses and closer looks in the video, it appears that he hit the upper fuselage. It doesn't matter really because he knew that the B-17 was there and he came in hot , fast, and obviously out of position, and in a tight turn toward the B-17 . I don't understand that part if it was, as they said, "It was a well rehearsed show." Off hand right now I can think of six airplanes that the CAF has destroyed, maybe more.
    Seeing the severed tail section of the B-17 immediately brought back memories of my squadron mate, Joe Frank Jones, whose airplane, "Mr. Lucky" was cut in half at the same spot as the "Texas Raider" and Joe Jones, the tail gunner, had to ride it down 13,000 ft. and survived.
    I won't count all the airshows that I have flown in but the big Bicentennial air show at Abottsford had a huge flyby of airplanes from WW1, between wars, WW2, and after. We flew all at once in several concentric orbits, (race tracks) with the older and slower machines in the inner tracks and the bigger faster types in the outer tracks. The rules and instructions were carefully gone over at the morning pilot's meeting where spacing and timing was specified and emergency procedures were addressed. There were perhaps 25 to 30 airplanes involved. After assembly and circling the field three times , the landings took place with the little and old stuff in the infield grass and succeeding big stuff in line on the runway. There was not one glitch in the three days that we performed. If you deviated from your time and position , you were grounded. I don't know if the military could have done it any better.
  18. BJK
    BJK F1 Rookie
    Jul 18, 2014
    4,785
    CT
  19. rob lay
    Dec 1, 2000
    59,566
    Southlake, TX
    Rob Lay
    You might know this question Bob, but most likely the B-17 was on a wider pattern and the faster planes were on an inside pattern. Either or both were out of position.
  20. intrepidcva11
    intrepidcva11 F1 Rookie
    3,215
    Saratoga Springs NY
    Seth
    Bob and Rob, I have watched and re-watched the brief video of this event not fewer than fifty times and my take is very different. Bob wrote:
    "It doesn't matter really because he knew that the B-17 was there and he came in hot , fast, and obviously out of position, and in a tight turn toward the B-17 . I don't understand that part if it was, as they said, It was a well rehearsed show."
    Although we will never know unless the P-39 pilot left a note, but I believe that this was a deliberate suicide attack.
  21. rob lay
    Dec 1, 2000
    59,566
    Southlake, TX
    Rob Lay
    another user mentioned that too. although possible, I think it is completely improbable and even crazy to mention. if you were trying to suicide attack, then you would have kept your visibility with your target.
    BJK, Boomhauer and crinoid like this.
