BA 747 hits building in Johannesburg | FerrariChat
Discussion in 'Aviation Chat' started by RWatters, Dec 23, 2013.
  1. RWatters
    RWatters Formula 3
    Feb 21, 2006
    1,075
    Kansas
  2. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    Someone is going to get their wrists slapped...
  3. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
  4. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,369
    Cheshire
    I see they are putting in a late bid for aero fail of the year 2013
  5. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Man how strong are these planes!!!
    Somebody though should lose their job.
    Pete
  6. jcurry
    24,071
    In the past
    Jim
    Given the current prices of 744's, and the number that are being parked, that one will be going to the scrap yard.
    Also, as they were taxing out for take-off, extremely lucky they did not have a big fuel spill. Definitely some damage in the region of the surge tank.
  7. jcurry
    24,071
    In the past
    Jim
    First clue would be the main bogies riding in the grass (almost). Doubtful that taxi-way is even rated for a 744 at gross.
  8. Tcar
    Tcar F1 Rookie
    It was dark... took place at night.
    Probably could not see the bogies... or the building????
  9. zygomatic
    zygomatic F1 Veteran
    5,062
    Washington, DC
    Chris
    I wonder how the taxiway is holding up. I can't imagine a GA taxiway is designed to support a 747
  10. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    I would say that you are correct, Jim. The spars, skins, and stringers are continuos from root to tip and there is no way to splice or do a sectional repair on any of it without some hellaciuosly expensive engineering and rework and it probably wouldn't work anyway. Added weight way outboard even if it is moderate can screw up the flutter and add local stiffening where flexibility is critical. I would be surprised if the wing didn't get wracked on top of everything else. A write off.
  11. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    I did read somewhere about a very large fuel spill, fire dept took care of it pretty quick. Will see if I can find it again
  12. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,369
    Cheshire
    If it's a write off, how would they physically remove the plane from the airfield?
  13. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,714
    ESP
    Bas
    This is Joburg...leave it unlocked for 20 minutes and it's gone :D
  14. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    Pretty lucky that there were no serious injuries or worse in the building.
  15. jcurry
    24,071
    In the past
    Jim
    Anything worth removing can be taken off right there on the airfield and shipped elsewhere, e.g. engines, doors, control surfaces, LRU's, etc. Even structural items such as door surround structure can just be cut out using a 'circular' saw or sawsall. The rest is just scrap metal. Like most machines the sum of the parts is much greater than the whole.
  16. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    Planes get cut up and hauled off pretty regularly though occasionally thu just sit for a while first if there is space.
    The DHL plane (757?) that took a missile at Baghdad International maybe 10 years ago basically is still sitting at the field last I saw. They took the engines off and probably stripped the avionics but then basically just parked out out of the way. There are a ton of old Iraq Airlines planes just sitting there in a jumble where they all got pushed together.
    There was a 717 in San Antonio that was just sitting there for years with no engines.
    In the last couple years there have been several C-130s cut up and trucked of from Little Rock. They were structurally damaged after being hit by a tornado a couple years ago. They pulled the engines, dismantled the control surfaces and then basically cut them up in manageable chunks.
    My guess is that they will paint over the airline insignia and pull all the valuable stuff like engines and electronics. Then they will just park it maybe cut it up depending on how much space there is.
  17. Ferrari_250tdf
    Ferrari_250tdf Formula Junior
    Mar 3, 2005
    479
    Didn't the B17 often made it home worse than that?!
    Best
    Matthias
