Backfiring through carb 79 GT4 | FerrariChat
Discussion in '308/328' started by 3px19, Sep 9, 2008.
  1. 3px19
    3px19 Karting
    Aug 29, 2006
    218
    Calvin crouch
    Need some help here.
    The rear bank of the car has been backfiring when I remove foot from gas. Plugs are pretty well sooted up when I check.
    Did a compression test, rear back is 175, 170, 175, 175
    Leak down test 13% 23% 11% 14%
    Checked the cam timing, it is appx 1/16" off the mark.
    Pulled the rear distrib, found valve gap really small, readjusted to .013
    Reinsert and timed it exactly for rear number one at 3ATDC.
    Put it all back together fired her up. Carb cleaner off so I could see.
    Idles nicely, when giving gas starts back firing . Noticed the emissions vapor hose that goes into the intake manifold was blown apart on the tranny side rear carb. This is the one that backfires the most.
    Thought maybe this was making it lean and causing backfire, Replaced hose and still backfires up the carb throat.
    OK, what do I attack now. Please give me soon direction.
    This is driving me nuts.
    thanks
    cal
  2. johnvwatts
    johnvwatts Formula Junior
    Jul 7, 2007
    523
    England
    John v watts
    Maybe a blocked idle jet. Pull the idle (slow run Jet) blow through then try again . There are 2 for each carb. Also note their size . With the air cleaner off - they are the brass screws on either side of the carb at the top.
  3. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    23% is a lot of loss, did you check where its losing pressure?
