Guys, Recently I have been afflicted by the window gremlins. The driver side switch that operates the pass window wasn't working at all. After some investigation I have finally found the problem.The wires are broken at the door pin connector, my question is does anyone know where the wires go on the pin connector? I have the two yellow wires broken off completely but also there are 2 more wires broken off and the pin connector has 5 empty connectors. If I remove the connector on the fender will that have the same color wires and I can just match them up? Thanks for the help. Tommy
