Buy
430 ball joints help !
Discussion in '360/430' started by Felix Yuen, May 21, 2021.
  1. Felix Yuen
    Felix Yuen Karting
    109
    Felix Yuen
    hi,
    been doing some research and it seems that if i don't replace the ball joints right away when it is starting to get loose, i will risk cracking the control arms.
    as some say that the arms are made with race grade but fragile material.
    is that true ?
    other than HILLS ENGINEERING stainless steel ball joints.
    are there any other "upgrade" options ?
    how are the AW ITALIE stainless steel ball joint kit ? any review or feedbacks ?
    360 430 Complete Suspension Kit - uprated-AW6360000 | AW Italian Auto Parts
    some say they are same as the pro sport ball joints upon closer inspection they look different
    Ferrari 360 & F430 Balljoints by Prosport – Aldous Voice
    any feedbacks or help would be great !
    what is the general labour cost for replacing all the ball joints
    thanks
  3. 24000rpm
    24000rpm F1 Rookie
    about cracking of arms, I've been driving with an a-arm with a play-y ball joint for a long time, nothing happens, but i drive gently. I'd say its possible for a crack but its not very likely.
    I've never intalled an aw italie so I dont know their quality.
    labor cost is region dependant, where are you?
    each coner has 2 ball joints. so total of 8 ball joints.
    Removing the 8x a-arms would take me, a decent weekend warrior about 4 hours. installing another 5 hours.
    replacing 8x ball joints probably takes about 3-5 hours, a lot more if you run into some sort of a problem. depending on if you have the tools ready.
  4. spider348
    spider348 Formula 3
    1,236
    MA
    Did the front lowers on my 360. Balance were all tight, no play.
    Service bulletin provides very specific bore tolerance for the A arms. If oversize, need new A arms as well.
    Used Hill Engineering Ball Joints. OEM spec epoxy.
  5. jag-oo-r
    jag-oo-r Formula Junior
    May 27, 2015
    398
    I just did my ball joints (front only, but upper and lower) this winter. I used Hill Eng. items, as they are just so robust and beautiful it didn't feel right to put anything else on there.
    240000rpm details labor times above, which could be about right, except you need to factor-in the time for the epoxy to cure in your oven. YES, you'll put them in the oven. I don't remember precisely the temperature, I think it's 120df or something like that, which is required to start the catalyzing of the epoxy. (check aldou's voice for more information)
