430 - Ball Polished Wheel Weight Sticky Remnants | FerrariChat
430 Ball Polished Wheel Weight Sticky Remnants
Discussion in '360/430' started by Extreme1, Mar 31, 2020.
  1. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,226
    Santa Clarita, CA
    I just pulled all the wheels off to do a brake fluid flush and the last new tire installer left the sticky part from the old weights on the inside of the wheels.
    Are the wheels clear coated? The insides of the wheels polished up nicely, except for where the old weights were.
    Can I use acetone to remove the sticky remnants or will that damage the wheel coating?
  2. tazandjan
    38,075
    3M Adhesive remover will do the trick, but I would want to test it on a back part of the wheel before using it on the front.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
    I think they’re clear coated so don’t use a solvent that will damage it. Goo Gone is fairly mild.
  4. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    I have found wend using Goo Gone for best result, take a small piece of clear plastic and place over the sticky part after applying Goo Gone and wait a few minutes and just wipe off works great
    Need4Spd likes this.
  5. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,803
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    Yes they are clear coated.
