Ballistics Experts: Question. | FerrariChat
Discussion in 'Other Off Topic Forum' started by UroTrash, Oct 18, 2004.
  1. UroTrash
    Jan 20, 2004
    40,509
    Purgatory
    Clifford Gunboat
    I've been wondering about this for a long tme.
    Lets say you have a rifle with a 1 in 12 inch rifling twist (I know, 1:9 to 1:14 depending) and a muzzle velocity of say, 2000ft/sec.
    That bullet would be spinning at 2000 rev/sec = 120,000 RPM.
    Can a bullet really spin that fast? Can anything spin that fast? That's 5 times faster than a router bit!
    Just think of a .22-250 at 4000 feet per sec and a 1:14 twist!
    Boggles my mind.
  2. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    Is your marriage in trouble again...?
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,175
    E ' ' '/ F
    Snike Fingersmith
  4. Rifledriver
    37,122
    Yes, they really do spin that fast. That is exactly why to achieve good accuracy a bullet has to be made with great precision. Can you imagine the the imbalance that would be created if the jacket material was inconsistant in wall thickness and the lead core was off center? That's one reason why good quality target (rifle) bullets (bullet only) are so expensive. It is also the reason that in some calibers of long range target rifles (we are always trying for higher velocities) the bullets blow up. It usually happens about 5-15 yards beyond the muzzle.
  5. DrStranglove
    DrStranglove FChat Assassin
    31,518
    Google Maps
    DrS
    Simply put, yes it is possible and readily quantifiable.
  6. UroTrash
    Jan 20, 2004
    40,509
    Purgatory
    Clifford Gunboat
    Does anything else on earth spin that fast? Seriously.
    I mean that is just incomprehensibly fast!
  7. DrStranglove
    31,518
    Google Maps
    DrS
    The electrons in an atom go a bit faster than that.
    A good puzzler would be if the outer ridge of your car tire is spinning at 55mph what is the inner most inch spinning at?
  8. UroTrash
    Jan 20, 2004
    40,509
    Purgatory
    Clifford Gunboat
    Yeah, I thought about atoms. Is there a manmade machine that spins that fast?
  9. Artherd
    Artherd F1 Veteran
    Jun 19, 2002
    6,588
    Bay Area, CA
    Ben Cannon
  10. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    NICMOS Cryocooler (NCC) Installation:
    Astronauts retrofitted an existing but dormant instrument called the Near Infrared Camera and Multi-Object Spectrometer (NICMOS) with a new, experimental cooling system to return it to active duty. NICMOS was placed on Hubble in 1997 but became inactive two years later, after depleting the ice it needed to cool its infrared detectors. By fitting NICMOS with the experimental cryogenic system, NASA hopes to re-cool the detectors to -334°F (-203°C or 70 K) revive its infrared vision, and extend its life by several years.
    The super-quiet cooler uses ultra-high speed microturbines, the fastest of which spins at over 200,000 rpm (over 50 times the maximum speed of a typical car engine). Hubble's engineering team successfully demonstrated this technology in 1998 aboard STS-95 in the first on-orbit test of a high-performance, high-efficiency, mechanical cryocooler.
  11. Erich
    Erich Formula 3
    Sep 9, 2003
    1,190
    Poway CA
    Erich Coiner
    How fast does a dental drill spin?
    Turbo charger Impeller?
    Turbo molecular vacuum pump impeller?
    I don't know the exact speeds these turn but they are high rpm devices.
    Erich
  12. teak360
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
  13. teak360
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
  14. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,782
    IgnoranteWest
    55mph?
