Banned from another forum. | FerrariChat
Discussion in 'Other Off Topic Forum' started by Noel, Oct 25, 2009.
  1. Noel
    Noel F1 Veteran
    I think I got banned from another forum, simply because I didn't post enough (nothing weird or negative). I entered the URL with a proxy and it comes up, so that's why I think I was banned. Anyway, I'd like to get unbanned or register with a different username, anyone know what I should do?
  2. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,280
    Seattle Area
    Dave
    Hi Noel - your best bet is to contact the administrator via PM (or a good
    moderator) and see what they can do. I would not recommend the 'new
    username' path - most likely your IP address will trigger a perma-ban. If
    you can't get to the site at all, use a different computer on a different network,
    which will get you to where you can make contact via PM or email.
    Good luck
    Jedi
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I was a moderator briefly on another forum (that has since gone "belly up"). There were members with more than 30 user-IDs that would populate their own threads with back and forth posts using different names. I got the hell out of there. :D
    One is enough.
  4. Peloton25
    Peloton25 F1 Veteran
    Jan 24, 2004
    7,646
    California, USA
    Erik
    It is highly unlikely that any forum would IP ban someone for not posting enough. Something doesn't make sense with that at all.
    Find the contact info for the owner or a site Administrator, because in most cases a Moderator probably won't have the power to solve your issue.
    >8^)
    ER
  5. Noel
    Noel F1 Veteran
    turns out I'm not banned, i logged in and emailed the Mod from my phone, no problem there. when I go to the site from my computer the page is totally blank, no anything, just white nothingness. everything else seems to work with any other page. ??
  6. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,973
    Wellington, FL
    Duane
    Clear your cache and reboot your machine, I had a similar problem here a year or so ago and that fixed it.
  7. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    Those people have seriously too much time on their hands. Weird.
  8. anunakki
    anunakki Seven Time F1 World Champ
    79,001
    Las Vegas Nevada
    Jerry
    I belong to a forum where if you dont make at least 25 posts per month they deactivate your account. But no ban.
  9. Noel
    Noel F1 Veteran
    it's something to do with my IP; if I try to access the site from my wired desktop, blank screen, if I try from my wireless notebook, blank...if I try from a different, Windows notebook, still nothing. if I try from my phone, no problem. any ideas?
  10. Jedi
    Jedi Moderator
    Mar 18, 2008
    32,280
    Seattle Area
    Dave
    Power down your cable modem for a few minutes - it will negotiate
    a new IP address with your ISP when you turn it back on. But not sure
    how such a site blockage would work due to IP issues, unless your IP has
    been in fact 'locked out' at the server. But easy and worth a go....
    Jedi
  11. Noel
    Noel F1 Veteran
    tried it. no-go.
  12. Carsleuth
    Carsleuth F1 Rookie
    Dec 22, 2006
    4,331
    Chicago/NYC
    Dan C.
    What forum is this? That sounds really weird. Did you contact the administrator about it?
  13. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    You might have to have it switched off for more than a few minutes. Some systems reserve the IP for a connection for some time (maybe even 24hrs) to speed up logins. To get around this you may need to call network support who can clear the reservations and thus allow a new IP to be issued.
  14. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Like Jerry said, I got deactivated from a forum for not posting for probably a year or two. I emailed one of the moderators and the admin and they reactivated me. I think I'll probably get deactivated again :D
