Baron motor replacement | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by 2000YELLOW360, Nov 26, 2015.
  1. wizzard
    wizzard Karting
    Nov 9, 2014
    93
    I have quite a bit of time in an IO 520 Baron that has had this treatment. What started out as a 285HP engine we estimated a boost to 300-310HP. The airplane performed noticeably better-better acceleration, vastly improved climb, and slightly faster cruise, all for about 1/2 gal higher fuel flow per engine.
  2. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    The motors I am replacing were similar. Hopefully these 550s will be even more. Friday!!!
    Art
  3. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Done. Picking it up tomorrow.
    Will post pics.
    Art
  4. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    Awesome. What a great XMas present!
  5. vincent355
    vincent355 F1 Veteran
    6,539
    Wine Country
    Vincent
    Art, always going faster! Happy holidays!
  6. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    #31 2000YELLOW360, Dec 27, 2015
  7. Tcar
    Tcar F1 Rookie
    Self-presenting on Christmas... good... always get what you want. :)
  8. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    I like the digital RPM / MAP displays.
  9. donv
    donv Two Time F1 World Champ
    26,374
    Portland, Oregon
    Don
    I like those as well. Is 2500 RPM normal cruise? I vaguely thought it was lower, but then it's been 25 years since I've flown a Baron...
  10. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    #35 2000YELLOW360, Dec 27, 2015
    I use 2400 normally, but this was break in. Not quite the 75% per book, but close. Initial climb at 200#s under gross was 2.1k, about 4-5 above book.
  11. wizzard
    wizzard Karting
    Nov 9, 2014
    93
    I love the digital engine gauges!
    Years ago I flew a V-35 Bonanza for a communications company. It had started life as an IO520 with 285HP. After having flown it in that configuration for quite some time, the owners sent it to Colemill to install a 300 HP IO550 with a four blade Q tipped prop.
    WOW! Just like yours, at level cruise up to 8,000 feet the VSI was always just bumping the bottom of the yellow arc. Serious power management was required for that airplane. It also had an astonishing climb rate. (It "probably" could carry more weight also-a lot more weight-again careful management of the airplane required) Same could be said of the Baron I flew with the same treatment.
  12. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,987
    wisconsin/chicago
    bo
    Very cool Art...
    Bo
  13. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,590
    Southlake, TX
    Rob Lay
    congrats Art on engines. my 400 is still kind of for sale 210 KTAS, 16 GPH, 4 people golf clubs & go, G1000. :eek:
  14. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Neat. There is a turbo normalize kit. If I were to install that (another 50k) it would be a 250 kt plane. I hate oxygen though.
    Art
  15. rob lay
    Dec 1, 2000
    64,590
    Southlake, TX
    Rob Lay
    I understand on OX, the nose cannula isn't great, but not that bad even 4 hour flights. a secret had a nurse show me was run the tubes over your ears and tighten under your chin. I love the 10-17k altitudes because hardly anyone flys there, you get direct everywhere.
  16. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    What airport do you keep your Baron at?
  17. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Ca35. San Rafael
    Art
  18. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Brought plane back for prop balancing and some adjustment. 6500 feet, 2500 rpm 202 kts. Climb 2.53 best rate (full fuel) cruise climb 1.3k. Plane is about 10-12 kts faster, but 40 gallons an hour. With 3.80 fuel so what....
    Art
  19. sigar
    sigar F1 Rookie
    3,683
    NorCal
    Nice. That's one of the fastest Baron's I've heard of.
  20. wizzard
    wizzard Karting
    Nov 9, 2014
    93
    I like those numbers!
