BAR's F1 world record attempt | Page 2 | FerrariChat
Discussion in 'F1' started by tifosi12, Jul 9, 2005.
  1. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,828
    @ the wheel
    Andreas
    If the high speed run in Bonneville goes well, I hope BAR will try this as their next publicity stunt.
  2. rcallahan
    rcallahan F1 Rookie
    Jul 15, 2002
    3,307
    Santa Barbara
    Bob Callahan
  3. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
  4. Mr Payne
    Mr Payne F1 Rookie
    Jan 8, 2004
    2,878
    Bakersfield, CA
    Payne
    Beast, I didn't read your link...however, I think this benefit would only work on tracks where drivers had the ability to be full throttle for a complete lap. I don't follow IRL so I don't know how common an occurance this is.
  5. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    This does only apply to tracks where the car runs flat out like at Indy. If you dig up some back issues of Racecar eng. they had a bunch of articles about the IRL blow overs. Mostly in the wake of the Tony Renna accident at IMS in late 2003.
    Here is one quote from the March 04 issue.
  6. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    They cannot take the wings off entierly as the rules require them. Also they are used to balance the car durring the race the only other way would be to move ballest at pit stop. For example if they run the wings flat and the car is still over steering the only way to reduce aerodynamic grip on the front is to go from a flat angle to a lifting angle to further reduce the down force on the front of the car.
    The front wing has the only means to make radical changes to Aero balance. Changes to the wickerbill on the rear wing is mainly there to make quick changes to the rear downforce of the car but it is minimal due to the suction created by the tunnels in the side pods.
  7. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    The other thing I think you have missed is that the downforce is NOT created by the wings but by the sidepod tunnels (as CART cars use "ground effects as F1 did in the 80's" minus the skirts [I think] and thus not flat bottomed like F1 cars).
    Thus remove the wings and they still would be producing downforce.
    Pete
  8. Mr Payne
    Mr Payne F1 Rookie
    Jan 8, 2004
    2,878
    Bakersfield, CA
    Payne
    Ok, makes perfect sense. Thanks for the enlightenment.
  9. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Date range for this attempt now set between Oct 4 and Oct 11. Gives them a week to choose days for the best weather conditions. Should be very interesting. Anyone know if SpeedTV will be covering this ?
    On a side note currently JPM has the distinction of the being the fastest man clocked driving an F1 car when he went 367 kph on Aug 25 when he broke the Monza lap record.
  10. tifosi12
    Oct 3, 2002
    49,828
    @ the wheel
    Andreas
    Oh, thanks for the update on the BAR attempt. Great, can't wait!
    Regarding JPM: I read that actually Kimi holds this record now after the Monza GP for being clocked at 370 km/h.
  11. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Yes ! I stand corrected. I hadn't read that but a quick search did indeed confirm KR was clocked at 370. Thanks.
  12. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    The Indy car thing has come up before, as PSK points out, they are still producing a ton of downforce even when the wings are setup for a small amount of lift.
    I thought Mark Webber ran 371 at Monza in practice, and Kimi held the during a race record at 370.
    I don't think 250mph is much to be concerned about, and the parachute is a bit theatrical. They were running 230 on a track last weekend where there is plenty of "instant deceleration" obstacles to keep in mind should one crash. There's nothing out on the salt flats... That said, it's totally bad ass, and I for one give BAR a lot of credit for continually doing outside the box thinking.
  13. F1racer
    F1racer F1 Rookie
    Oct 5, 2003
    4,749
    Laval
    Jean
    I have ...Villeneuve 375 km/h and Montoya 374 km/h during test days at Monza. (3 weeks ago) And yes Kimi did 370 km/h during race day.
  14. VMax
    VMax F1 Rookie
    Nov 21, 2003
    2,862
    Perth, W.Australia
    Mike Sharpe
    Cos you can't stick sponsor stickers to thin air!! :)
    I think the safety concerns about the BAR attempt are a bit excessive, as has been mentioned they do not far off 400km/h at Monza already, and there's a lot more stuff to hit there :)
    Additionally, I'd be more inclined to be sitting in a megabuck, crash-tested, regulated to the moon F1 car in a 400km/h crash than I would some of those "home" built jobs that run out there at the same sort of speeds - not that I'm suggesting those aren't safe or well-engineered, I'm sure they are, but there have been a lot of F1 crashes in the last ten years and they've all provided data to improve safety even further.
  15. reospeedwagon
    reospeedwagon Rookie
    Aug 17, 2005
    38
    Sacramento
    Chris
    I think this idea is kind of dumb. They should instead see how fast they can get the thing around the real Nurburgring.
  16. pizzadude
    pizzadude Formula 3
    Feb 20, 2001
    1,283
    Indianapolis, IN
    I was thinking the same thing.....250 is fast but not so amazing. The single unofficial lap record at Indy is somewhere around 239.
  17. Admiral Thrawn
    Admiral Thrawn F1 Rookie
    Jul 2, 2003
    3,932
    The fastest achieved last year was 369kmph by Pizzonia at Monza.
    The reduced downforce this year helps the cars on the straights, but hampers them considerably in the corners. That's why we have higher top speeds this year (on some tracks... depends on the entry to the straight) yet lap times 1 - 2 seconds slower than last year.
  18. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Apparently the flats are under an inch of water. Bummer. :(
  19. tifosi12
    Oct 3, 2002
    49,828
    @ the wheel
    Andreas
    Darn.
    I read an article about their preparation for this event: They already raced at the Flats with one of their test drivers. He did some test runs and commented that the thoughest thing were the bumps. It caused so much vibrations, that he had a hard time seeing out the car and seeing the line (or cones?) that he is supposed to follow.
  20. EspritSE
    EspritSE Formula Junior
    Dec 1, 2003
    509
    Colorado
    Craig
  21. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    very cool, would like to see on TV.
  22. SPEEDCORE
    SPEEDCORE Four Time F1 World Champ
    Jul 11, 2005
    46,182
    Toe Knee
    They should do afew runs with current 2005 specs, and afew without the specs, just to see the difference.
  23. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Apparently BAR on Fri ran at the Mojave airport and did two-way runs that averaged over 400 km/h. The last run was 415. Seems they can't get to Bonneville until May or June next year for their runs there.
  24. tifosi12
    Oct 3, 2002
    49,828
    @ the wheel
    Andreas
    CART just lost their motto "Fastest race cars in the world", which always irked me. Way to go BAR!
  25. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Not quite sure how CART could've claimed rights to that as I'd think that would have to go to a Top Fuel dragster.
