Basic tuneup | FerrariChat
Basic tuneup
Discussion in 'Technical Q&A' started by docweed, Apr 17, 2005.
  1. docweed
    docweed Formula Junior
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Is there any manual/reference material/publication that explains the BASIC details on how to tuneup a 79 308? The threads on the subject are usually specific to a particular problem. I would just like to be able to tuneup my car myself. There is a lot of info on adjusting the balance on the carbs. so I just need guidance on the electrical adjustments ie. setting dwell, points gap, timing etc. I have a timing light and a dwell meter. I got a CD on parts, workshop manual but it is limited and not much on how to.
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Balancing 4 Weber carbs is not an easy job for a DIY first timer unless you have a friend with you who knows what he's doing. Getting everything at optimum performance takes some experience; although you can dive on in with your Haynes book in hand and give it a go. The worst thing that will happen is it won't run really well and you'll have to take it to someone. But in the long run you'll save big bucks since it's almost all labor.
    I don't understand what you think you don't know; the points adjustments are all in the manual as is the timing. You'll want to check the advance to be sure it's correct. I did mine in the car: my son revved in 1000 RPM increments and I checked the advance via flywheel marks. I don't know if the twin distributor set up is as straight forward. If the advance IS off, you'll be playing with springs and weights...
    I've always gone on the assumption that I can screw up my car for a lot less money than a mechanic and when it comes to basic tuning, there's not much permanent damage you can do by accident so I say go for it!
    Ken
  3. docweed
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Ken
    Thanks for your reply. I do have experience with Webers as I converted my 75 911 from FI to carbs. I had to build the carbs from scratch and then remove the FI and insert the Webers. I tuned them with a Uniflow and it runs fine. I don't know how to tune the electrical stuff with two distributors. Is the dwell meter set on 8 cyl or 4 cyl? How much variance is allow between the dwell on one bank versus the other? Do you use the same mark for timing for both banks of cylinders? Do you use #1 spark plug wire for the rear bank and a different wire for the forward bank? There are more questions but if I knew the above answers I could get a good start. Thanks again.
    ps. The Haynes you referred to is that the one on Weber Carbs. or is there one on how to tune a 308 engine? I have several books on Tuning Weber Carbs. Is there a Haynes on servicing the 308? Does it exist? I don't have a manual for the 79 308...can't find one and I wander if there was one.
  4. FourCam
    FourCam Formula Junior
    May 19, 2004
    411
    Greeley, Colorado
    Cameron MacArthur
    Background: I have had my 79 308 GTS for 15 years, and do all the work myself. Get a shop manual first, even if it is for the 308 GT4. Almost all the info is the same. The version I have is translated from Italian-sort of. Refer to your High School Latin! If I may be so presumptuous, I would suggest the following: take your distributors to a reputable shop to have them "set up". this means having the advance curves set, point gaps set (dwell), and will save you untold hours of frustration. It ain't cheap, but it is really an essential baseline for any performance. When you get them back, mark the flywheel with two different color paints on the two TDC marks for each cylinder bank. This will allow you to set each distributor to it's corresponding bank with a timing light flashing on the correct mark. I did mine in white and red. The shop manual will show you the relationship between the two banks. You are really setting up two four cylinder engines on the same crankshaft, with their own ignitions. Then, if you don't already have one, get a carb synchronization device that will measure airflow into each venturi (carb barrel), and go to work on getting each one equal to the next. This procedure is spelled out in the Weber manual. This will take anywhere from 15 minutes to a case of beer, depending on your skill and how far off the carbs were to start with! Most importantly, BE PATIENT! When you get everything right, you will be astounded at how well your car runs for 179 cubic inches, and you will have a great deal of pride in knowing that the job was done right--by You! Good luck!
  5. docweed
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Thanks a million. At this stage of my OJT all info is appreciated. Thanks again.
  6. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    This is really true. My Lotus is just one 4 cylinder engine as opposed to two, so it was a good car for me to cut my teeth on. It took me 2 years of trial and error learning before I had it tuned to it's optimum, but the results are astounding. I bet I was only getting 75% of the HP before and I must be getting 98% now. I had it tuned twice by my mechanic and he didn't squeeze out the HP I was able to get. I'm a big advocet of carb car owners to learn how to do this stuff because you'll ultimately do a better job for a fraction of the cost.
    Ken
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,655
    San Carlos, CA
    Mitchell Le
    Go for it.
    Basic tune up will include
    spark plugs, maybe wires, cleaning up of points and condensors and caps (replacement is very expensive). Oil change, and replacement of oil/air filters.
    Timing for your 2 dizzy uses two different marks, one for each bank with the timing light connected to either 1 or 5 wire. When you have time, convert to Crane Cams electronic boxes (2 of) to eliminate the points and condensors. YOu will still need the dizzy caps and rotors.
    If you have experience with webers, you will be just fine with the balancing.
  8. docweed
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Should there be a condenser on both distributors for this 79 308? There is only one on the forward distributor.
  9. geekstreet
    geekstreet Karting
    Feb 7, 2005
    220
    Cam
  10. yelcab
    Nov 29, 2001
    13,655
    San Carlos, CA
    Mitchell Le
    One condensor for each point is needed.
