Bass guitar help | FerrariChat
Bass guitar help
Discussion in 'Other Off Topic Forum' started by AnotherDunneDeal, Dec 1, 2008.
  1. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    Our son is advancing on in his music career and I need some advice here. He is majoring in music performance at TCU. He began playing the violin at the age of 9 and plays it pretty well. He picked up the tuba/sousaphone when he enrolled back in the public school system in the 8th grade after home schooling. He became rated the #1 high school player in Texas his senior year and TCU gave him a very large scholarship to attend there. His primary instrument is Tuba.
    His tuba professor, who has an incredible resume, has suggested that he begin playing the bass guitar also. The professor, along with being an accomplished tuba player himself, is a bass player also. He says that learning the bass will go along well with his music performance degreee.
    Now the question. I do not need to purchase a professional performance guitar but one that will do well for him to begin playing on. Purchasing pre-owned is the preferred method and it seems there are some good deals available. Can any of you give me a direction to proceed in that will allow him to learn the basics and have something that he can keep for a while. Also, what kind of amp will he need. He will not be performing on the guitar but using it to expand his knowledge. Any help will be appreciated as I know many of you know a vast amount about this.
  2. LUV 4REZS
    LUV 4REZS Formula Junior
    Aug 7, 2008
    659
    Newport News VA
    Leonard P
    #2 LUV 4REZS, Dec 1, 2008
    These are a few thing that you should look for when buying a used base or lead guitar:
    1) Check to see if the neck is straight from the body to the tuning pegs.
    2) Make sure that you plug it in and try the volume and tone controls to make sure there is no static present.
    3) Make sure the pickups are wired good and solid, most of the time you can unscrew the back and look at all of the connections.
    4) Check all of the frets to make sure they are in the neck good and solid.
    5) Check for buzzing on the frets.
    6) Check that the screws that connect the neck to the body are tight and none of them are striped.
    7) Check the pegs that hold the strap, make sure they are good and tight and not striped.
    Other than that just have him plug it in and give it a try and see how it feels to him, good luck!
    Forgot about the amp, just plug it in and make sure the speaker isn't torn anywhere. Listen for buzzing in the speaker, check all of the connections, other than that it should be ok.
  3. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    Any suggestions on brand and model? I know First Act is a joke. I found a Dean today that appears to be in pretty good shape for about $100. I understand Dean is made by Fender.......
  4. Carsleuth
    Carsleuth F1 Rookie
    Dec 22, 2006
    4,331
    Chicago/NYC
    Dan C.
    I really think the quality of Squier basses have gotten a ton better. I own a Fender 5 string and a Squier 4 string fretless as my two main basses. (even though I do play mostly upright) I would say Squier.
    Best of luck!
    Dan
  5. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Don't know what the standards are today, but I owned and played the Fender Precision Bass along with the Fender Bassman amp. It was a great setup.
  6. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    I found a 4 string Squier today, red body. It was marked $149.95. He offered it to me for $99.95. It appeared to be pretty solid. I may go back and talk to him about it. We did not discuss an amp today.
    Thanks for the help......
  7. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,410
    SFPD
    Dirty Harry
  8. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    I guess I need to research it further. I am a total rookie when it comes to discussing guitars........Cars I know a little about and can usually converse fairly intelligently, but guitars...........which end do I hold and I always thought a g-string was a ...............
  9. ADON
    ADON Formula 3
    Feb 8, 2007
    1,059
    #9 ADON, Dec 2, 2008
    Nothing wrong at all with pre owned. Quality is most important. If you buy a K-Mart guitar, it's going to sound like one. Don't buy something because it's cheap though, but a Dean for starters should be fine. Don't buy a $199 "kit" that comes with an amp from places like Guitar Center. They are junk. I good used guitar and good used amp will be much better.
    Any name brand should b fine. Fender, Dean, B.C. Rich, Gibson, Ibanez, Squire, Yamaha
    A half decent NEW bass will cost around $300 or so, and go up from there.
    I'm guessing this is the Squire bass you're looking at for $150?
    http://www.guitarcenter.com/Squier-by-Fender-Affinity-Series-Bronco-Bass-Guitar-510426-i1146354.gc
    If so, I would probably not get it. It's a 30" shortscale bass. Meaning it's not full size. A full size bass will be 34". It's like a bass with training wheels for noobs who have never played an instrument.
    If you just want to see if he enjoys playing bass for a quick $150, it's fine. But it's not a long term instrument. If he takes a liking to the bass, I would get something else for the longer term.
  10. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    #10 AnotherDunneDeal, Dec 2, 2008
    It is a used Squier. I am going back tomorrow to see the model number. It is used and is a 34" bass. You can tell it has been played but wear is minimal and the mechanicals all seem solid. We will plug it in tomorrow to see how it sounds. But, I am not settled on it. I am depending on some good advice from you guys. I will heed what you have to say since I know so little about guitars. I bet I will learn something about them before this is over though.
    I appreciate the advice. When we bought his tuba for college, we looked around and found a Meinl-Weston Thor C Tuba.
    http://images.google.com/imgres?imgurl=http://images.misupply.com/products/thumbs/Meinl%2520Weston/274792.jpg&imgrefurl=http://www.misupply.com/Meinl-Weston-c63%2B4294939865.music&usg=__JHw8sF7bWOW3neNUDl0XPk0rh20=&h=100&w=100&sz=34&hl=en&start=7&um=1&tbnid=j5TR9VETpFmqKM:&tbnh=82&tbnw=82&prev=/images%3Fq%3DMeinl-Weston%2BThor%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26channel%3Ds%26rls%3Dorg.mozilla:en-US:eek:fficial%26sa%3DG.
    It was new and pretty pricy but we consider it an investment in his future if he plans on making a living from performing, clinics, consults and education. I consider it a tool of the trade. The Thor is a newer tuba and is now well sought after and there is a backlog of orders for the brass ones, not the silvers (sound/tone is more mellow). His tuba professor, who is also an accomplished bassist recommends a middle of the line model to start and says to look used to get more value for the dollar spent. I tend to agree with him.
  11. LUV 4REZS
    Aug 7, 2008
    659
    Newport News VA
    Leonard P
    This is a pretty godd write up about buying the equitment that you are looking for:
    http://www.yourbassguitar.com/bass-guitar-amps-15/
  12. futureowner
    futureowner Formula 3
    Mar 24, 2006
    1,469
    Brookfield, WI
    Thad
    My bass guitar is a Fender Precision Bass Lite I believe. Haven't played it in forever, from what I remember I heard that for some reason, as far as a bass is concerned, the Fenders that are made in Japan seem to be a bit better quality than the others.
  13. tazz99
    tazz99 F1 Rookie
    4,449
    Kennesaw, GA
    Seth
    My son has been playing bass for about 4 years. Started with a First Act, about 2 months later we gave that away and went to a Peavy. Good tone, good quality at a reasonable price. Now he plays a Fender Jazz bass (US Made) Be careful with the Fenders, some are Mexican made and there is a noticable difference in quality. Also has an accoustic but that is a different story.
    I suggest your son start with a reasonably priced instrument to see if he even likes it, then move up to a high end instrument if he wants to continue with it.
  14. yoda
    yoda F1 Rookie
    Sep 27, 2004
    2,598
    UT
    #14 yoda, Dec 2, 2008
    I've been playing double bass and bass guitar for the past 18 years. I started off college as a music major with a scholarship much like your son. I think it's a good suggestion for him to learn bass guitar, it will go along well with his tuba performance. There are a lot of good brand name bass guitars out there that will work for him. It's best if he can try out a few basses and get one that feels good to him. Neck width, string spacing, overall feel, etc. are different on every bass (it might be hard for him to tell the difference now, but as he gets more proficient he will). I also suggest you only get a 4-string bass for now and one with a full 24 frets. Fender Precision and Jazz basses are good, the Squire series are the entry level models. I have really loved my Yamaha RBX800a bass, I can get great tone out of it and the playability is excellent. I think Yamaha basses are underrated and a used RBX series Yamaha would be a good choice. They originally cost $900 new and can be found for a fraction of that price. I had an Ibanez 6-string fretless for a long time, Ibanez is another decent brand that a lot of bass players start out on. Once purchased, I'd suggest getting the bass 'setup' by having an expert adjust the bridge, truss rod, etc. especially if you buy used. Also, string selection can make a big difference, an expensive bass with old or cheap strings can sound terrible and a cheap bass can sound better with some good quality strings.
    As for an amp, it doesn't sound like he needs anything too much. A decent quality bass practice amp should be fine for now. If he gains more interest in bass playing he can always upgrade equipment and instruments, and it's usually pretty easy to sell your old stuff. As for another suggestion, he may want to eventually look into double bass seeing that he has a background in violin. There are some good paying gigs out there for weddings, jazz clubs, etc. on the double bass.
  15. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    #15 350HPMondial, Dec 2, 2008
    Not to mention Hoe Downs,,,,,
    (I got the blisters to prove it.)
    Bass is fun....damentle...!
    Edwardo
  16. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    Fender, Gibson or Carvin, you should be able to find decent quality without spending to much.
    Stay away from the cheaper lines they tend to go out of tune and have bad action, and take away from the fun of playing.
    Any small brand name bass amp should be good. Again the cheaper ones just are not worth it.
  17. Carsleuth
    Carsleuth F1 Rookie
    Dec 22, 2006
    4,331
    Chicago/NYC
    Dan C.
    Double Bass is the sh*t, thats all I gotta say. I've been playing for almost 12 years now and I love it. My true passion since I was 3. Darolls I had no idea you played bass!
  18. Carsleuth
    Carsleuth F1 Rookie
    Dec 22, 2006
    4,331
    Chicago/NYC
    Dan C.
    Squiers are great I'm telling you, perfect for your son. Durable too. It's a great sounding bass with a great feel and a great price. As for an amp, this is a good starter amp:
    http://www.guitarcenter.com/Fender-Rumble-15-Bass-Combo-Amp-102496759-i1145410.gc?source=4WFRWXX&CAWELAID=92175313
    Good volume, nice EQ and not too heavy.
  19. fred cat
    fred cat Karting
    112
    ...Since no one else will start, I will. (Q)"What do you call a bass player that breaks up w/ his girlfriend"? (A) "Homeless" (Q) "how do you get a bass player to turn down his amp"? (A) Put sheet music in front of him. (Q) What do you do when there is a bass player at your door? (A) Pay him for the pizza. Next...
  20. EC308
    EC308 Formula 3
    Aug 28, 2005
    1,146
    jenkintown, pa
    ed
    (Q) What did the bass player get on his SAT? (A) Drool
  21. Carsleuth
    Carsleuth F1 Rookie
    Dec 22, 2006
    4,331
    Chicago/NYC
    Dan C.
    Offensive much?
  22. yoda
    yoda F1 Rookie
    Sep 27, 2004
    2,598
    UT
    A bass player's fingers are like lightning, they never strike in the same place twice.
