Batteries... | Page 2 | FerrariChat
Batteries...
Discussion in 'Technical Q&A' started by Whisky, Oct 20, 2022.
  1. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    For older cars, it's not an issue: 308, 355, 360, no sweat. Dealing with the electronics on something like the 458 or later and it's a totally different animal.
    Ray
  2. tbakowsky
    Sep 18, 2002
    20,043
    The Cold North
    Tom
    Yes..I did.mention that if you notice in my post.
    RayJohns likes this.
  3. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    All I'm noticing right now is a caffeine rush :)
    Ray
    tbakowsky likes this.
  4. Ak Jim
    Ak Jim F1 Veteran
    9,754
    North Pole AK
    I have several optima batteries although they are all older. Where did the optimas you had leak? I’d like to double check the ones I have. Thx.
  5. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    I had an interstate purchased with the car, it lasted about 4 years, replaced it with a yellow optima which lasted 3 years despite keeping car on maintainer. I wouldn’t pay extra for optima unless I needed a battery that was not on level surface.
    Now have antigravity lithium ion (Li- iron so not risk or fire like li cobalt). Been good for >5 years. 48 Ah 1500CCA. Like 3 lbs. got mine on sale for less than 500 bucks. Now same battery is like 850. And the company now recommends higher wattage 60 Ah 1800 CCA for Ferraris due to parasitic draw which is $950. I personally can’t Just can’t justify that much.
    So now I would use interstate from Costco. I’ve returned batteries to them up to 4 years and they give replacement battery without pro rating.
    It would be cheeper and healthier if I lost 25 lbs and went with a heavier and less expensive battery!
    f355spider likes this.
  6. f355spider
    f355spider F1 World Champ
    18,055
    They all leaked through the two black vent caps on top.
  7. f355spider
    18,055
    The Antigravity ratings are for the lesser used Cranking Amps (CA) rating. Not Cold Cranking Amps (CCA) that is more stringent. No way they can put out that much CCA. Yes, they have raised recommendations on the Amp Hour (AH) recommendations, which is wise, as I always thought they were recommending under capacity batteries for all their recommended applications.
  8. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    You are correct i didnt realize that they used CA not CCA.
  9. hessank
    hessank Formula 3
    1,954
    Canada, Florida
    Fred
    As was mentioned earlier, I used to freak out about batteries too.
    In 2014, as soon as the car was in my garage I changed the battery (among other things).
    I installed an Optima Red Top.
    I also purchased a battery tester and keep the car on a maintainer.
    Every time I put it to bed (early winter- mid Nov) I test the battery. In the spring before waking it up I test the battery.
    After 8 years it is still passing my tests but last year I removed it and had it load tested at a local shop to verify my little tester.
    Damn thing passed. Yet, I installed a new battery since I figured the space was already empty.
    The old Optima is now being used in my winter beater Acura MDX and going strong. After 8 years the CCA is 10% less spec.
    Go figure!
  10. fatbillybob
    Aug 10, 2002
    29,274
    socal
    Teach me something guys. I have not noticed newer cars BMWS most sensitive or 458's needed special batteries? The key in selection for me has always been to be in the OE cranking amp zone and that could be violated if the electrical load was reduced like in a racecar with no A/C system to turn on, and never started in freezinf temps because racecar.
