Battery 430 | FerrariChat
Battery 430
Discussion in '360/430' started by kurtflies12, Dec 2, 2017.
  1. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    Had my 2005 on the charger for a few weeks but when I attempted to start her there was nothing. No lights bells or whistles. Is there a recommendation on batteries? anything I need to know about replacing it?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
  3. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    How old is your battery?
    Is its over 3 years old I highly recommend removal and replacement asap.
    Lots of threads on battery removal and replacement. Just kindly do a search.
    Sorry I'm currently unable to send thread links.I
    Dan
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Just get a decent one, be carefull connecting the cables as not a lot to work with.
    Put some insulation tape on the small socket u use on the 12 v positive connection bolt, so u dont short it on the brackets
  5. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Same here, just went to run the '08 430 through a warm up cycle and ......nowt doin!
    Now I get why vodaphone (UK tracker) were trying to contact me the other day, even though my car hadn't been touched....doh!
    I will now spend a few hours reading battery threads (specifically UK available types).
    My car is still under a remainder of Factory warranty (1 yr to go), as a consequence hopefully I don't have to get the battery replaced by an F dealer.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Ferrari OEM battery costs mega money and the ferrari cover does not include it, so you will be buying that yourself. Varta are a good one
    whatheheck likes this.
  7. mello
    mello F1 Veteran
    5,493
    CA Bay Area
    Steve
    To remove old battery: disconnect negative battery cable first, positive cable second.
    To install new battery: connect positive cable first, negative cable second.
    No chance of sparking or shorting the battery if you follow the above. :D
  8. rugby
    rugby Formula Junior
    Apr 10, 2015
    364
    Atlanta
    To add to the above, before you do anything, turn off the battery switch in the front trunk. Turn it back on only after the battery has been installed.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Just bear in mind the battery switch is in the negative line and only breaks some of the negative connections
  10. rugby
    Apr 10, 2015
    364
    Atlanta
    I think the battery switch breaks all the negative connections with the exception of the alarm siren.
