Battery change for California | FerrariChat
Discussion in 'Technical Q&A' started by NMBmedicine, May 22, 2021.
  1. NMBmedicine
    NMBmedicine Rookie
    Mar 1, 2021
    5
    Washington DC
    Marcus Bush
    Battery change Image Unavailable, Please Login My car battery is drained and needs replacement . The car won’t start and it’s in a low clearance underground parking garage. It can’t be towed to the dealer or AAA. Since we can’t jump start a Ferrari how can I replace the battery? Where can I get information on what’s the best battery to replace it with. I found a repair guide online but no video online. Apparently isn’t not a quick swap.
    Each time the battery is disconnected from the electrical system all the acquisition parameters are cancelled from the injection ECU. There parameters must be reacquainted before using the vehicle. What does that even mean ?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Pretty sure there's this sort of information already in the California section
    I think your owners manual says how to restart after battery disconnect round about p204
  3. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Crystal Lake, Illinois
    Alex
    If possible, call the nearest Ferrari dealership. You need to know the correct battery for your car, and the correct way to install it so that the car doesn't lose necessary data. There are posts in the California thread regarding this, as greyboxer has already mentioned. Good luck!
  4. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    How's the car, Marcus? Were you able to get a new battery?
  5. NMBmedicine
    NMBmedicine Rookie
    Mar 1, 2021
    5
    Washington DC
    Marcus Bush
    I ended up putting the charger on in the middle of the night. I live in a condo that doesn’t allow using the garage outlets. It charged for 6 hrs and car started thankfully. Calling the dealer today for the best battery option.
    alex likes this.
  6. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    Keep us posted!
  7. NMBmedicine
    NMBmedicine Rookie
    Mar 1, 2021
    5
    Washington DC
    Marcus Bush
    I called the dealer and they charge $1150 to change the battery. They use Odyesey.
  8. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Hi, are you driving the car at least 2 times a week ? If you don't, you must find a way to use a trickle charger or this problem will happen again.
    Roberto
    alex and tomc like this.
