Battery charge | FerrariChat
Battery charge
Discussion in 'Ferrari Discussion (not model specific)' started by alexdxb, Jul 13, 2015.
  1. alexdxb
    alexdxb Rookie
    May 25, 2015
    26
    Hi all, I have a 575/355 and 612 that I'll be storing, can anyone recommend a suited brand or recommend what battery chargers to use pls ? Tks
  2. jzcar
    jzcar Karting
    Mar 23, 2012
    157
    N Florida
    Google CTEK. They're the best. You can search for them here also and see what those in the know are saying about them. Several interesting posts have appeared here over the years about this new technology for not just charging but regenerating batteries.
  3. DrJan
    DrJan Formula Junior
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    I have used Deltran Battery Tenders for ages. They are the best.
    You do not need a 'battery charger" but a "battery tender".
  4. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,665
    Manning, SC
    Robert G. Zambelli
  5. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    +1 for Deltran.
  6. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    CTEK if you have an ODYSSEY battery.
  7. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    Amazon "Battery Tender"
  8. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    I have also used the Deltran "Super Smart Battery Tender" for almost 2 decades. Still have one & use it on occasion. Until maybe 7 years ago, I would have universally recommended the Deltran - but I had one (that had been connected to a car for over 3 weeks) decide to go up in smoke & flames just out of the blue. Luckily, it was sitting well outside the car on a non-flammable table.
    Currently, I mostly use a CTEK "Multi US 25000." It is quite a bit more advanced than the Deltran, but also costs a bit more.
    I think both are excellent products and the CTEK can do everything the Deltran does, but the Deltran can't come close to doing all the things the CTEK can do.
  9. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    Could the Deltran have been full of dust and spiderwebs or similar?
    The fuses should have triggered if the maintainer was faulty.
    For this reason I only use maintainers that are outside the car.
  10. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    I have the Ferrari tender (which is likely the CTEK with the Ferrari wrap :D)
  11. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    I assume the battery in the cars are AGM. Make sure your tender is capable of charging AGM, and if it is adjustable make sure you set it to AGM.
    CTEK is a quality brand and is owned by the same parent corp that owns the company I work for, and we cooperate on a few projects. With that said, there are several name brands of chargers and IMO none of the top brands are junk. So if you find one locally and get a warm & fuzzy from the salesman, you are probably fine. Assume about $100 each.
  12. David_S
    11,260
    Mountains of WNC...
    David S.
    #12 David_S, Jul 15, 2015
    The only fuse in the Deltran is the one on the leads that attach to the battery - no internal fuse, so if something in the box goes "wonky," it will be all smoke & flames unless a house breaker happens to trip.
    Cracked open one of my other units used in the same environment & sure don't see any dust or spiderwebs...
  13. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    Looks spotless!
    I have a fuse in all the wall plug, plus the big fuse in the fuse box.
    Not sure if that is a standard with a fused wall plug in your countries.
    I had to select those specifically I built the property.
  14. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    It is scary we pay around 100 bucks for that. Value what, 50 cents in parts?
  15. southnc
    southnc Formula 3
    Dec 25, 2013
    1,765
    Charlotte, NC
    Adam
    Deltran Battery Tender Plus for my 612 - no issues so far.
  16. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    As others have stated, Deltran Battery Tender. Just get a four bank and be done with it. Should be ~150, and a few 25' extensions if you should need those too. It gives you a way to look in one spot, instead of hunting for each tender. I have many of these and they work great!
  17. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    #17 abstamaria, Jul 16, 2015
    The chargers that come with Ferraris are CTEK. The replacement chargers that Ferrari sells are also CTEK. Porsche chargers are also CTEK. l don't have a Lamborghini but understand their chargers are CTEK as well.
  18. Tom y92
    Tom y92 Rookie
    Sep 24, 2013
    41
    New port richey fla
    Tom y
    After reading the thread about the charger/mainteners going up in flames,this is the reason why I shut off the battery when I leave the car stored.I wouldn't trust anything electrical attached to my car at any time.Good luck to all you guys that trust the little black boxes.
  19. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    I do not trusty those Made in China things too, hence the fused wall plugs. You can choose a weak fuse, just enough for the gadget not to trip it. In addition to that I would never mount one of those in-car models, the ones that are permanently attached.
    And I place it on a brick in case something should happen, so the painted floor will not get damaged.
    I know, "belt and suspender" approach, but it works!
    To shut off the battery means the computers have to reboot each time? Is that good?
