Battery Charger and Charge Point | FerrariChat
Discussion in '348/355' started by f328nvl, Jan 31, 2013.
  1. f328nvl
    f328nvl Formula Junior
    Nov 10, 2004
    851
    Herts
  2. WATSON
    23,918
    WI
    That guy is a putz.
    His biggest ***** about the 355 is the battery location? That is his "electrical" concern??
    He obviously never owned a Jaguar and its Lucas electrical characteristics...or a late model GM product that has batteries so buried it takes a week to extract them.
    He deserves the Audi he likes some much. I hope he has since sold his 355 to a real man.
    What a putz.
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,706
    South East
    Jimmie
    Its John's blog and he only posted that today so.......
  4. WATSON
    23,918
    WI
    oooops....
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    John I have owned my ferrari for a long time and I have yet to replace the battery. My 355 and I believe the 348 both have the cut off knob right where your wire came out. What I am trying to say is that inmany years I have not even needed a trickle charger and that's leaving the car for 6 months at a time. So the good news is you will probably only need to change it once so it is not as bad as you might think.
  6. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    OMG that was much ado about nothing. The proper charger location is the lighter in the cabin. Mine is under the rear bonnet. I would never consider fastening it to the actual battery.
  7. Turbo Ron
    Turbo Ron Formula Junior
    Nov 3, 2003
    262
    West Los Angeles, CA
    Ron Stavis
    I think mine is attached to the battery. Whats wrong with that?
  8. WATSON
    23,918
    WI
    #8 WATSON, Jan 31, 2013
    Nothing if it is a basic battery tender.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I think it has to be charged at the battery if you are going to use the factory cutoff otherwise no power goes anywhere
  10. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Thats where it should go. Many are too lazy to do the work and yet its so easy.
  11. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Really?
  12. Reddesire
    Reddesire Formula Junior
    May 7, 2008
    388
    Melbourne, Australia
    Andrew Gaal
    .... I hook up a battery top up unit (trickle charger) everytime the car is not in use at the charge points outlined (there the same in the 348 as the 355 by the looks of it) and going on 5 years the car starts perfectly even after a month or more in hybernation (by that time I have Ferrari withdrawal symtoms and have to get it out so its never been dormant longer than that :) ).
  13. WATSON
    23,918
    WI
    Y'all might want to read the above comment again.
    Hooking a tender cable to the battery and having it pop out in the front truck is pretty easy stuff and avoids confusion when storing the car with the cut off switch in the off position.
  14. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    I use the tender and I connect it at the back. It's easy and simple. No need to bother with the cutoff switch, just leave it on all the time.
  15. apex97
    apex97 Formula Junior
    Nov 25, 2006
    593
    Stockbridge, GA
    Edward Zabinski
    Its not that unusual. The Mid year Corvettes had the battery in a similar spot on the left side behind the left front wheel. required the wheel to be removed to replace. The battery is a huge chuck of weight, the lower you can get it, and any thing else which is heavy, in the car the better it will handle.
