Battery charger option | FerrariChat
Discussion in 'Technical Q&A' started by Schumi76, Feb 24, 2006.
  1. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    Is it possible to retrofit the battery charger option connector on a 360 model ?? Any ideas ??? Thanks !!!
  2. Rifledriver
    37,089
    Yes you can but I would advise against it for monetary reasons.
    Factory charger is very expensive and not very reliable. We had a very very high failure rate on them.
    There are lots of very cheap dependable units out there. Buy one and use it.
  3. awhite
    awhite Formula 3
    1,229
    still here
    hmmmm
    I agree,,
    dont waste your money on a factory unit, get a smart charger, and hardwire a plug to the connectors behind the drivers seat...
    plug it in when needed..
    -a
  4. Schumi76
    Feb 15, 2006
    329
    NC
    Marco
    Thanks Brian and Adam !!!!
  5. Schumi76
    Feb 15, 2006
    329
    NC
    Marco
    Adam,
    what do you mean with behind the driver seat. Are there some terminal connections from the battery ??? Isn't the battery located behind the passengers seat footrest ???
    Will this one work: Output: 12 VDC, 1.25 A, Brand: Battery Tender Plus.
  6. awhite
    awhite Formula 3
    1,229
    still here
    hmmmm
    Behind the drivers see (under the pane;) are direct leads to the battery and ground)
    -a
  7. 458italias
    458italias Karting
    Sep 15, 2012
    148
    Cleveland Ohio
    if there is a plug there say a male ac outlet plug what should connect to it a charger? or does this indicate someone installed the charger already and you plug the male ac pigtail into the wall?
