Battery Charger Port on 360 | FerrariChat
Discussion in '360/430' started by Keith360, May 12, 2018.
  1. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    I purchased a factory charger cable, the one that stays with the car. I had hopes of finding a mating connector to wire into my AGL charger. I had the manufactures name and part number of the stays on car half. Should be easy to find a mating connector right? Also, the location they placed the connector is poor. Lift the bonnet, remove the three screws that cover the brake fluid reservoir, and make the connection. Again, poor placement.
    So I used the factory connector and spliced into a new connector. I fabricated a bracket installed. Easy to access and the bonus is the warning light shows the charger is connected.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    where did you get that cable and connector? Is there a factory P/N?
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Pretty creative!
  4. Keith360
    Feb 6, 2015
    570
    Keith Williams
    The connector shown is from eBay
    Link
    https://www.ebay.com/itm/3-Pin-Power-Connector-Male-Plug-Female-Socket-Waterproof-IP67-Heavy-Duty-Metal/122388322155?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    The Ferrari “BATTERY CHARGING CONNECTION CABLE”. There are two part numbers dependent on the car assembly number.
    Car Assembly Number: 43439
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/360-group/360-spider/battery/178566-charging-loom.html
    or
    Car Assembly Number: 43440
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/360-group/360-spider/battery/200857-battery-charging-connection-cable.html
    Found four on eBay, I think I paid $115 for mine a couple of years ago.
    Part Number:178566
    https://www.ebay.com/sch/i.html?_from=R40&_nkw=ferrari+178566&_sacat=6001&_fosrp=1
    Part Number: 200857
    https://www.ebay.com/itm/Ferrari-360-430-575-599-612-Battery-Charger-Link-Cable-P-N-200857/401485030780?hash=item5d7a5f657c:g:t2IAAOSwvGlab5ds&vxp=mtr
    I think either one would work if you’re considering a modification like mine.
    As for wiring, and I guess you could cut the connector off in your car and butt splice the wires direct. There are three wires, one +12vdc (RED), one ground (BLACK), and the Signal (RED/White) to trigger the warning light.
    I drilled and tapped the square tube just inside the opening to 6-32.
    Keith
  5. Keith360
    Feb 6, 2015
    570
    Keith Williams
    Thank you Bob
  6. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    wonderful
    Many thanks
  7. Keith360
    Feb 6, 2015
    570
    Keith Williams
    I’m glad I was able to help.
  8. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Huge help indeed.
    Planning on a move to Carpinteria.
    So maybe I will get with you later on
  9. Keith360
    Feb 6, 2015
    570
    Keith Williams
    Hey, no problem, I can assist.
  10. Keith360
    Feb 6, 2015
    570
    Keith Williams
    Another cool feature or PITA if don't like inhibit functions.
    If you have the charger connected, as the factory intended and as I modified my 360, the starter will not crank. This prevents the accidental movement with the charger connected.
    Other inhibit function are with F1 transmission gear, the door open, and you let off the brake the transmission with change to neutral.
    Spider top will not activate while engine hood is open.
    Anyone seen any others?
