Battery Charger Tender -458 | FerrariChat
Discussion in 'Technical Q&A' started by Julius Rosa, Jan 10, 2019.
  1. Julius Rosa
    Julius Rosa Rookie
    Sep 14, 2018
    1
    Julius Rosa
    I just purchased a 458 this Summer, I’m driving it at least once a week. Someone has told me I should plug it in all the time. It’s been starting up , with no problems so far, maybe a bit hesitant towards the end of the week, I thought to use it when I go on holidays, after a week or more. Do you in install the cord through open passenger window,thanks for any advice.
  2. bball16
    bball16 F1 Rookie
    3,863
    NY LI FtL
    I just run the wire under the door and I plug it in whenever 3-4 days have passed without driving it.
  3. Caeruleus11
    Caeruleus11 F1 World Champ
    10,893
    Welcome to the family! You should definitely plug it in if it's going to sit for more than 2 days.
    The included tender is pretty good, but I would recommend swapping it out for something more robust such as the 7002 CTek.
    This is a few dollars higher than if you'd buy the parts separately but you get the idea.
    https://www.ebay.com/itm/Ferrari-CTEK-MUS-7002-Battery-Charger-Adapter-360-F430-458-California-599-612/192365458849?hash=item2cc9dff5a1:g:WasAAOSwBkRaDI60:sc:USPSPriorityMailLegalFlatRateEnvelope!10577!US!-1:rk:1:pf:0
    bball16 likes this.
  4. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,886
    DFW, Texas
    Tom C
    +1 on the 7002. If your F-car has HELE (stop/start), you'll want to charge it in "snowflake" mode. Congrats on the new car!
    T
    bball16 and Caeruleus11 like this.
  5. bball16
    bball16 F1 Rookie
    3,863
    NY LI FtL
    That's what I use too.
    Caeruleus11 likes this.
  6. docf
    docf Formula 3
    Sep 14, 2008
    1,356
    Florida
    Gary
    The 7002 is a much better tender than factory as noted. Run the cordage under the front of passenger side door. There is a natural space Ferrari put there for running the cord into the cockpit. If you run the cord haphazardly you will eventual fracture the electrical cord. Like others pointed out plug the car in if your driving frequency is like you noted.
  7. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Or, you can use a Deltran Battery Tender Plus for under $80 which will last for years and be replaced free if it ever fails. Available from most auto parts stores.
    I have over 20 years of satisfaction with these. One failure was replaced, no questions asked. 599, Gallardo, Avalon currently plugged into one each.
