Battery charger | FerrariChat
Battery charger
Discussion in '360/430' started by howl, Jun 15, 2014.
  1. howl
    howl Formula Junior
    Apr 10, 2011
    505
    Chicago/Boca
    Tom
    Did a search but the threads are dated.
    i have a Cteck 3300 for my other cars. See the Cteck 4.3 is recommend. There are two 4.3 models. There is the Multi US 4.3 and the MUS 4.3. I thought they were the same but they are listed separately on the Cteck website and are about $10 in prices. Any thoughts or recommendations?
  2. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I have the CTEK MUS4.3 and it works fine. Get their pigtail adapter too as it will show you when to plug in the tender (it has lights on it and the connector matches the tender.
    Alan
  3. howl
    howl Formula Junior
    Apr 10, 2011
    505
    Chicago/Boca
    Tom
    #3 howl, Jun 15, 2014
  4. tclark
    tclark Formula Junior
    Jun 4, 2004
    604
    Mechanicsburg, PA
    Tom Clark
    Looks identical to mine, a "Battery Tender Junior" made by Deltran.
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Yep, Battery Tender pigtail
    Sent from my SGH-M919 using Tapatalk
  6. BigJay2050
    BigJay2050 F1 Veteran
    7,191
    Save-A-Battery also uses a similar pigtail, I would imagine they are compatible.
  7. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    I have one from battery tender and one from WalMart--both with the same pigtail.
  8. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,491
    Honolulu
    Kevin
    Pigtail is standard for Granite Digital Chargers too. I really like these because they say how much voltage they are charging at any one time!
  9. conscom
    conscom Formula Junior
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Standard trailer light connector. The exposed contact is negative.
  10. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    CTEK have the connector for that type. Mine already had that connector hooked up so I used the that to connect and then the CTEK pigtail connects to it. Or you can remove that and use the one that comes with the CTEK.
    Alan
