Battery conditioner question | FerrariChat
Discussion in 'F12/812' started by Adriangandy, Nov 23, 2023.
  1. Adriangandy
    Adriangandy Rookie
    Feb 23, 2017
    11
    Los Angeles, CA
    AdrianGPA
    Please excuse my naivety, but i'm currently trying to charge my Ferrari F12. While the manual says remove the socket (Do I just remove the socket by force? I don't want to break anything) Or do I remove the whole lid?
    Thanks!
    Best.
  2. Rabies
    Rabies Karting
    Apr 4, 2020
    167
    If you mean the socket and associated plug for the charger in the boot of the car, the F12 has a bespoke Ferrari fitment and the plug should have a small clip on the top that your depress to release it from the socket and it should pull out of the socket easily. The socket in mine has been moved due to some modifications to the audio system, but I believe that socket in the boot either has a small spring loaded cover or a push tight one that you open to fit the plug.
    Adriangandy and Caeruleus11 like this.
  3. Adriangandy
    Adriangandy Rookie
    Feb 23, 2017
    11
    Los Angeles, CA
    AdrianGPA
    Thanks for the help! So i'm just gonna pull that socket yeah as shown above? Thanks thanks
  4. Adriangandy
    Adriangandy Rookie
    Feb 23, 2017
    11
    Los Angeles, CA
    AdrianGPA
    tried removing the plug, can't seem to do so- is it normally hard to remove? Won't budge :/
  5. Caeruleus11
    Caeruleus11 F1 World Champ
    11,438
    It’s been a long time for me with the F12 but I think the connector you need to reach is just behind that panel, which is removable. It should be on clips / not too difficult to remove
    Adriangandy likes this.
  6. Rabies
    Rabies Karting
    Apr 4, 2020
    167
    Not sure about that - mine doesn't have a cover as it has been re-fitted - you could try prying the cover off with a flat bladed screw driver of something?
  7. Adriangandy
    Adriangandy Rookie
    Feb 23, 2017
    11
    Los Angeles, CA
    AdrianGPA
    Yes yes! I removed the whole damn panel because the plug was stuck. So much easier! Thanks!
    Decided to remove the panel altogether. Thanks for the help brother!
    Caeruleus11 likes this.
