Battery conditioner/tender connector | FerrariChat
Discussion in '456/550/575' started by 2000 456M, Nov 17, 2009.
  1. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    #1 2000 456M, Nov 17, 2009
    I purchased a Ferrari branded battery conditioner on ebay and when it arrived I noticed that the connector (which the accompanying manual said was for all late model F-cars but only included instructions for the 430, 612 and 599) looked like a computer connector. It did not fit the standard two circular prongs near the battery that I believe other tenders plug into.
    In checking my 456M manual, it made no mention of the circular prong connectors; instead, it said that a battery tender could be connected by an optional connector on the left front fender above the wheel arch. My car didn't have that option installed. Has anyone ever had that option and, if so, does it fit the late computer style connector used in the 430/612/599? Or do I sell the conditioner to a fellow f-chatter? Can anyone set me straight on this?
  2. tazandjan
    39,195
    #2 tazandjan, Nov 17, 2009
    Allan- The optional 456M battery charger portal was on the port side of the engine compartment near the windshield.
    I thought the Ferrari kits came with an adapter for alligator clamps. No?
    Boardwalk gave me a Ferrari badged CTEK when I bought the car and I found an empty Schedoni battery charger case to store the charger.
    Taz
    Terry Phillips
  3. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    That's what the diagram in my manual shows, but I don't have that connector and it doesn't look anything like the connector that came with the battery conditioner. When I get home tonight, I'll take photos of the conditioner connector, the battery side connector in my car and that section of my engine compartment that lacks the connector and post them all. Hopefully I'll get some enlightment or better yet "here's a $2 adaptor to connect the two prong battery connector to the conditioner". THAT would be sweetest.
  4. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    #4 ferraridriver, Nov 17, 2009
  5. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    That's the type of "two prong connector" that's attached to my battery that I was talking about. Are you saying I should cut off the connector supplied with the conditioner? I'm reluctant to do that until I've gotten to the bottom of the connector issue using the factory parts.
  6. bobwass
    bobwass Karting
    146
    Los Angeles
    Bob Wass
    i bot a fcar charger on ebay, didn't open for several months, and found out i didn't have the multi prong adapter either. i'd be interested to know if it's available.
    gutviz likes this.
  7. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Exactly what happened to me. I ordered it in June and, when it arrived, my wife immediately took it and put it away to give me for Christmas. Came November and the weather stayed bad for a couple of weeks and I said, "sorry, Hon, I need it now..."
  8. bobwass
    bobwass Karting
    146
    Los Angeles
    Bob Wass
    so that's at least two hanging on fcars somewhere.............................
  9. vnttg
    vnttg Formula Junior
    Jun 13, 2007
    262
    CA
    I bought a regular CTEK from Ebay (shipped to me from a shop in Costa Mesa, CA, I think) for my 2000 456, connecting directly via the cigarette lighter. Worked perfectly. Once I left the car for almost 2 months unattended during my summer vacation, no problem whatsoever. I think the unit costs around $60-$80?
  10. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    #10 ferraridriver, Nov 17, 2009
    Yes, you can't use it anyway, just make sure you have the polarity correct.
    Or you could always just buy a Battery Tender which comes with those connectors and sell the Ferrari one
    http://www.batterytender.com/
  11. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    I was hoping for a more elegant solution that would enable me to keep the Ferrari conditioner in its original form. I also noticed that the plug is more complex than merely two wires, so there must be some kind of data that passes between the conditioner and the car beyond just shoveling electrons back and forth...
  12. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    I know there are cheaper alternatives that work equally well; it was just on an indulgent whim that I got the Ferrari conditioner. And now I want to make it work, dammit.
  13. tazandjan
    39,195
    Allan- You probably can build an adapter cable, which would solve your problem.
    But, if I were you, I would contact the folks who repair the Zivan chargers here in the States. Tell them your problem and see if they can provide you an adapter that will work and not trash your car's ECUs. Should not be that expensive.
    http://www.zivanusa.com/
    Taz
    Terry Phillips
  14. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    #14 2000 456M, Nov 17, 2009
    Thanks, Taz. I'll email them my info and some photos, but maybe it's time to call the dealer or yell "Rifledriver, heeeeelllllpppp!"
  15. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    I use Battery Tender on all my cars and bikes. Fantastic unit and cheap.
  16. tazandjan
    39,195
    #16 tazandjan, Nov 17, 2009
    Sometime during f430, 612, and 599 production, Ferrari changed from the large, complicated, and heavy Zivan charger to the lightweight, simple, technically advanced, and small Swedish CTEK battery charger. Ferrari branded, they run ~$200. Unbranded, a top of the line CTEK on E-Bay is $69.95. I have one of the Ferrari branded CTEKs provided with my car (used) by Boardwalk. Works great.
    Still nowhere near the panache of that Schedoni case that came with the Zivan, which is why I put mine in a Schedoni case.
    Since the Zivan and case brings $350-700 Allan, you have great choices.
    http://www.ricambiamerica.com/product_info.php?products_id=337780
    Taz
    Terry Phillips
  17. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    #17 2000 456M, Nov 18, 2009
    Thanks for the diagrams, Terry. Although they aren't sufficiently detailed, I'm guessing that the plug end of the connector for my Ferrari Ctek conditioner, which is round, plugs into the same round socket option (18-20,27-28 in the diagram) as the Zivan Schedoni-encased tender does even though the unit looks like #33 except for the plug. I'll click on the ricambi link and see what they're pricing the option for. Are the 9-16, 26 mods also necessary?
    "Charging Loom": $289.13 from Ricambi. Time to announce the availability of my conditioner in the 612/599 and 430 sections.
  18. tazandjan
    39,195
    #18 tazandjan, Nov 18, 2009
    Allan- The accessory Ferrari CTEK charger the dealers sell comes with alligator clips, and those are what I have been using. It does come with a relatively simple connector as well if you want to play with that.
    Daniel should be able to get you one although I could not find them on his site except the factory ones with the weird connector.
    http://www.etoolnet.com/buy-ctek-3300-battery-chargers-at-etoolnet.html
    The generic ones are as little as $55 through discounters. They come with connectors for the positive and negative battery posts and a quick connector. Attach those and plug in. Imagine this one with red paint and Ferrari script if you want the Ferrari one for $100 more.
    Taz
    Terry Phillips
  19. Jsuit
    Jsuit Formula 3
    Jul 12, 2005
    1,178
    East Coast
    I have this one. it is great
  20. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Couldn't you just put a small rectifier in the trunk and do away with the need for household 110 current completely?
  21. tazandjan
    39,195
    Dave- Perpetual motion machine? What powers the rectifier?
    Taz
    Terry Phillips
  22. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    My short term solution is going to be to drive the car every time there's a break in the weather. That's what I did last night, making sure the oil got up to 150 F.
    I'll also poke around the battery a bit on the outside chance that I missed something. Maybe another connection option in a non-standard location might have been put in (the first owner ordered a number of dealer-installed options--tubi, full 3m--, even though he didn't spring for shields or daytona inserts). If all this comes up negative, I'll just sell the conditioner to a 430/599/612 owner and move on to a pig-tail connected tender.
  23. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    That's easy--the battery!
  24. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    The battery of course, silly, which is constantly being maintained by the conditioner which is powered by the rectifier.
    Its simple really, I don't know why you can't grasp the concept.
  25. bobwass
    bobwass Karting
    146
    Los Angeles
    Bob Wass
    #25 bobwass, Nov 18, 2009
    taz - you are brilliant, why didn't i think to look there, the cable is $46, the cheapest thing i'll ever buy for the 550!!!!!!!!!!!!!!!
    bob
