Battery Cut-off Pickle | FerrariChat
Discussion in '360/430' started by Michael Cross, Nov 5, 2023.
  1. Michael Cross
    Michael Cross Rookie
    Jun 20, 2020
    4
    Michael Cross
    Hello Folks,
    So I was putting my '09 F430 away for the winter, wash, fuel stab, charger, etc. I disconnected the battery via the cut-off switch in the boot...and of course, closed the boot. I have a perfectly fine battery charging away for the winter BUT no power to open the boot, or anything else for that matter!
    Any thoughts would be greatly appreciated!!
    Best,
    MC
  2. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    There should be a manual boot release under the dash.
    flash32 likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,955
    Central NJ
    Dominick
    +1
    Right near the steering column
  4. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,426
    Santa Clarita, CA
  5. Michael Cross
    Jun 20, 2020
    4
    Michael Cross
    Thanks so much everyone, Need4Spd, Extreme1, Flash32!! Looked int he manual for "Boot Release" but its page 44 of the manual under "Luggage Compartment". LOL!
    Cheers and thanks again
  6. Ferrarista98
    Ferrarista98 Formula Junior
    284
    Jason L
    Time to ditch that relic and get a true classic like my 355. Boot release is a nice latch left drivers foot well.
    my guess is there’s a probably a fuse jumper or the like you can use to open? Common problem for anyone with a dead battery.
  7. Qavion
    Qavion F1 World Champ
    14,344
    Ian Riddell
    Fuse and relay are in the frunk.
    Mario Andretti and INRange like this.
  8. Ghostdiver
    Ghostdiver Formula 3
    Mar 18, 2005
    1,348
    Southeast Texas
    Wally Hollar
    If you haven't found it, there should be a manual release the dash. Cable 23 goes into the passenger compartment under the dash. On the 360 it's between the steering column and drivers door close to the lower dash. On the 430, I would think it's in the same area. HTH.
  9. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    My tip is to open one of the doors so the window drops it's predetermined 1". Keep the door open until you disconnect the battery with the cut off switch. Every time I forget to do that when I go to open the door to retrieve something from the car and the battery is in disconnect mode, the glass does not drop (of course) and it pops out of the upper rubber seal to the body--- and I cringe.
  10. CoreyNJ
    CoreyNJ Formula 3
    2,476
    New Jersey Shore
    I just always lower the windows whenever I work on the car, just incase you have to reach in for something without even opening the door.
