Battery cut-off switch for 550 | FerrariChat
Discussion in '456/550/575' started by oceans, Oct 9, 2010.
  1. oceans
    oceans Karting
    Jan 3, 2008
    155
    Jacksonville, FL
    Rob
    Hey folks,
    I've been getting tired of finding my 550 will not start due to battery drainage from the alarm system. Aside from the clock and the radio presets losing juice, are there any vulnerable systems that could cause me problems later from having no power? I have my doubts about battery tenders (as do a lot of my car collecting friends).
  2. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #2 toggie, Oct 9, 2010
    My battery tender works great.
    I use the inexpensive kind you can buy anywhere.
    Comes with two leads, one you can bolt on the battery leads and leave on the car.
    I prefer to leave the car on the tender rather than power everything down with the battery disconnect switch.
  3. fatbillybob
    Aug 10, 2002
    29,018
    socal
    Many collect older cars. The more computers in the car the more the choice goes towards tenders. It seems that electronics does not like on/off power issues and power spikes. Especially with Ferraris if you cut power sometimes it can be a bear to get drive cycles to reset so you can do a smog test. My thinking these days is to cut the power as little as possible.
  4. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Battery tender.
  5. tazandjan
    39,175
    Rob- The battery in your 550 should be good for 2 weeks between good drives with no problems. If it is draining more quickly than that, you probably have a leak/short. There is a simple test you can do to test whether you have a problem.
    Your battery could also be on its last legs and a new one might improve things. The new absorbed glass mat batteries are very strong, but expensive. The Interstate MTP91 is the most cost effective solution and mine works great. Search battery in this forum for extensive battery discussions.
    Taz
    Terry Phillips
    Taz
    Terry Phillips
  6. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    when I bought the car it was wired for it so I just plug it in ...
    It's very odd for me not to drive mine for two weeks, but I have used it when it was close.
    It's very cheap insurance.
    Take care,
    Bill
  7. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I've been using Battery Tenders for at least 15 years, race car, cars in storage, drivers when traveling. I must have half a dozen of them. Never had one fail or cause a problem.
    All my cars are hard wired for them.
  8. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    #8 308 GTB, Oct 9, 2010
  9. Northwest 550
    Northwest 550 Karting
    May 20, 2009
    71
    Washington State
    Brown M. Maloney
    No battery cut-off switch in any modern Ferrari - for that matter, no cut-off switch in any modern car.
    Battery Tender or the equivalent.
  10. open roads
    open roads F1 Rookie
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Battery tender, absolutely.
    Put the lead to the battery where you can get to it easily. Mine is behind/under the trailing edge of the hood.
  11. oceans
    oceans Karting
    Jan 3, 2008
    155
    Jacksonville, FL
    Rob
    I appreciate the replies.
  12. JazzyO
    JazzyO F1 World Champ
    Jan 14, 2007
    12,156
    The Netherlands
    Onno
    That is what I have on my 550 - a socket in the nose to plug in the battery tender without opening the hood. Just perfect.
    Onno
  13. Gharagozloo
    Gharagozloo Rookie
    Mar 21, 2005
    20
    The batter tender sold by Porsche for around $130 plugs into the cigarette lighter and works great. Give it a try.
  14. stan996turbo
    stan996turbo Formula Junior
    Jun 11, 2004
    711
    Philadelphia
    Stan
    I have the same, it's the best way to go.
  15. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,582
    Grant
    #15 Wheels1, Oct 11, 2010
    Has anyone tried using the cigar lighter to charge there 550?
    The manual says " no electrical devices must be plugged into the Cigar lighter"
    I use one of these, the smartest charger in the world [ or so it says] about £40
    Grant
    http://www.ctekchargers.co.uk/?gclid=CNfd7YGpy6QCFSL92AodvGjicg
    Oceans
    I assume that you cannot turn off the isolator switch for security reasons, the battery should last for several months with it turned off.
