Battery Drain Tests | FerrariChat
Battery Drain Tests
Discussion in 'Technical Q&A' started by rimoore, Dec 31, 2007.
  1. rimoore
    rimoore Formula 3
    Nov 18, 2004
    1,353
    Island in Maine
    Richard Moore
    #1 rimoore, Dec 31, 2007
    Electronic Guru's : My 348 was dead as a doornail the other day. I recently installed a new Optima red top so I know the battery is in order and I've tested the alternator and that's working good. I did a battery drain test today and I think it's reading 114 milliamps, which I think is normal. Can someone verify this is correct? When doing my tests I discovered that the positive cable wasn't that tight. That may be my problem.
  2. Steve Magnusson
    26,764
    No, (unfortunately) that's not correct. Your measurement is showing 1.14 A (1140 mA) which is much too high for a long-term situation -- but make sure this isn't something short-term like a piece of added electronics doing a self-test after a power cycle (since you broke and remade the power connection when you placed the Ammeter is series -- i.e., keep measuring for say ~5 minutes and see if it decreases to a lower long-term value). If your long-term value stays at 1.14 A, that's definitely something that needs to be investigated and corrected -- good hunting!
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    As Steve has said your meter is reading 1.14Amps, which is way too high. But even 114ma is too high unless you have 3 alarm systems, a GPS and two stereos. Draw on a stock 348 should be around 20-30ma.
  4. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Even if it was 114 mA it is still too much of a draw. A brand new car battery with that use while the car is off would only last a month. Most cars probably use only 20 to 30 mA at most.
    aehaas
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You're on the right path to finding your problem. Keep your meter in place and simply start pulling out relays from your passenger footpanel. Note the drop after you pull every 3 or 4 relays.
    You'll quickly narrow down your problem circuit. If the problem persists with all of the footwell relays out, then start on your fuses under your front hood.
  6. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Try removing any aftermarket devices, radio, amp, alarms etc. Like everyone says , the current draw is MUCH too high.
  7. rimoore
    rimoore Formula 3
    Nov 18, 2004
    1,353
    Island in Maine
    Richard Moore
    Thanks for the help guys. I pulled the fuse on my amp, which had just been professionally installed, and the draw went down to .03. I'll have to call the audio guys and see why my amp is drawing so much power with the car off. Appreciate the help.
  8. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    Nice find mate ;) too bad on the fault though, you might find they probably got slack and wired the remote on direct off the constant V12+ supply :p
  9. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Most external car amplifiers require a voltage from the radio to indicate whether the radio is on or off. Sounds like this signal is missing and the amplifier is on full time. Purpose of this is to prevent exactly the problem you are having...it is to reduce idle current to nada when the amplifier isn't in use. Perhaps your installers needed to save a bit of time or just didn't know better.
  10. rimoore
    rimoore Formula 3
    Nov 18, 2004
    1,353
    Island in Maine
    Richard Moore
    Look like the remote power is working. It's an old...old PQ10 amp and there must be something wrong with it.
  11. chris marsh
    chris marsh F1 Veteran
    5,758
    Detroit
    Chris Marsh
    FYI
    I bought an optima battery for my race car the battery in it was old and I knew the car had some wiring issues.
    After installing the Optima everytime I went to start the car the battery was dead. A freind came over and we spent the weekend re-wiring the entire car. I still had problem with the baterry dying. I took the battery back to the store where I bought it and they hooked it up to a number of meters and assured me it was fine.
    Something didn't seem right to me because the first meter they hooked it to only showed 10 volts. So well I was at the store I picked up a $50 battery and when I got home I put the new battery in the car and have not had a problem since.
    Since Optimas are so expensive I wonder how long it was sitting on the store shelf before I bought it???
  12. chris marsh
    5,758
    Detroit
    Chris Marsh
    By coincidence I was listening to "The Car Show" on the radio this weekend. The guys on the show said we used to by batteries and the store would install the acid and the initial charge. Nowadays batteries are shipped with the acid installed and it is 3-4 months before they leave the factory, 3-4 months in the distributors wharehouse, 3-4 months on the retailer shelf, so they are 1-1.5 years old by the time we get them.
