430 - Battery Drain | FerrariChat
430 Battery Drain
Discussion in '360/430' started by mike32, Aug 20, 2023.
  1. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    My battery has a constant drain which i have traced to fuse AF17. ( 15 amp rating ) in the front boot space. Manual says this is Blinking internal lights, hazard blinking indicators, direction indicators. Current draw is 0.4 Amps. It must also supply the light in the front boot.
    Anyone have any experience with something similar ?
  2. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,758
    England
    Mark
    Does the car beep when you unlock it?
  3. Rifledriver
    36,856
    I did some time ago on a 360. The flasher module up under/behind the glove box was hot to the touch. Something internally had gone south. I replaced it and it was all better. Unplug it and see if the battery draw goes down to where it should be.
    EastMemphis, mike32, Qavion and 2 others like this.
  4. Qavion
    Qavion F1 World Champ
    13,989
    Ian Riddell
    AF17 fuse feeds the Hazard/Turn Module and the Interior Lights Timer Module.
    The Interior Lights Timer controls the front boot light as well as the interior dome light. It doesn't provide power to them, but I imagine it will use a little power to control the earth to the lights. 0.4 amps seems a little high though, unless it has a similar issue to Rifledriver's flasher module. Note that the F430 Flasher Module has a different design/pin configuration to the 360's.
    Latest wiring diagram here:
    https://www.dropbox.com/t/ZXgpaicPFXwJcEQE
    I'm not sure where the Interior Lights Timer Module is on a RHD 430, but on a LHD it's possibly up around the driver's left knee area.
  5. jerbear27
    jerbear27 Formula Junior
    292
    CT
    Jeremy
    Out of curiosity, what if it doesn’t beep when you unlock it?
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,758
    England
    Mark
    That's a good thing. A beep (or several) is a code to indicate that the alarm was triggered or that one of the closures e.g. hood isn't secure.
    jerbear27 likes this.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    Update, the flasher unit was ok, turns out the 0.4 amp drain is coming from the front boot light, having the boot open to read the meter, tripped the latch by hand and now zero. Looks like the only draw on the fuses is related to the window switches, between 0+0.1 A on each fuse. Light is on permanent on each switch and never found out why. Door bleep is normal
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    Re Max fuses by the battery- No4 is a 60 amp labeled in owners manual as 60A +30 front guard. This is drawing 0.7 amp with front boot open, pull the fuse and front boot light goes out. Trip front boot switch and this drops to 0.3 amp which makes sense as front lamp was taking 0.4 amp. Still a loss of 0.3 amp somewhere.
    Max 3 fuse loss of 0.06 amps- label is 50A+ 30 AC
    Remaining max fuses are zero
  9. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,758
    England
    Mark
    That's why I asked about the bleep from the alarm, Mike. It indicates that one of the closures isn't secure - in this case the luggage compartment which leads to the light being on permanently.
  10. Qavion
    13,989
    Ian Riddell
    #10 Qavion, Aug 21, 2023
    Maxi fuse 4 feeds fuses AF2, AF6, AF10, AF14, AF18, AF1, AF5 (switch lights, but not the window switch lights), AF9 (Instrument Panel), AF13 (internal lights timer, etc) and AF17.
    Maxi fuse 3 feeds the HVAC ECU and the blower fan speed controller ("hedgehog"). Not sure why this would draw current with the ignition turned off. Does the ECU have any memory circuits?
    HVAC diagram here:
    https://www.dropbox.com/t/2Hj6VUrqJiWWOWyl
    Window switch lighting power comes from the Window ECU. I assume there are circuits in there to keep things active for certain time periods. Live battery power goes to the Window ECU via fuses behind the LH seat (PSF3 and PSF7)
    Window diagram here:
    https://www.dropbox.com/t/PEaaJD3SjgQcjhPl
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    I will try putting my phone in there to record, but if i trip the bonnet catch by hand the light goes out, so i think it is ok
    mwstewart likes this.
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    I checked everything in the front boot, only draw was the AF17 @ 0.4 amp and when i tripped the boot catch and boot light went out it was zero. But still have a 0.3 amp draw on max4 fuse
    From what i recall the light on the window switches should go off after a while but they dont. The car has a fuse for each window but the amp draw effects each fuse , both switches have same stay on issue
  13. Qavion
    13,989
    Ian Riddell
    Did you find the Internal Light Timer module? Try disconnecting that or pull fuse AF9.
    (EDIT: I see you already checked those fuses)
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    Any idea where it is ? From what i recall the door switches and internal light have same fuse, i think i was measuring the flow on this and turned off the light, shut the doors and then had zero amps
  15. Qavion
    13,989
    Ian Riddell
    Pulling AF9 should have the same effect, but I see you may have already checked the current on that.
  16. Qavion
    13,989
    Ian Riddell
    It's not really clear from the parts or wiring diagrams
    Passenger's left hand knee (RHD car)?
  17. Qavion
    13,989
    Ian Riddell
  18. LorenzoR
    LorenzoR F1 Rookie
    Looks like it's mounted against the side wall
    Qavion likes this.
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    I think i see one of your wallets tucked behind it, that will be well padded then
  20. LorenzoR
    LorenzoR F1 Rookie
    lol
  21. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    I have 2 Greggs sausage rolls in the oven heating up, i bet you miss them
  22. Qavion
    13,989
    Ian Riddell
    31% of daily intake of fat... mmmmmmm (according to their website)
    Actually, I don't remember them (from my childhood). I only remember Yorkshire pudding and cold pork pies (not served together).
  23. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    Only once a week and i never use big mac or the kfc down the road
    Qavion likes this.
  24. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,925
    Isle of man- uk
    Using my phone, the front boot light goes out when you close it
  25. Qavion
    13,989
    Ian Riddell
    Did you notice a delay on the light? It is hooked up to the timer. If you lock yourself inside, I guess it gives you enough time to see and pull the internal release handle (on USA cars at least).
