Battery for 328 | FerrariChat
Battery for 328
Discussion in '308/328' started by magnum15, Feb 28, 2008.
  1. magnum15
    magnum15 Karting
    Oct 31, 2005
    147
    Tucson,AZ
    Gary
    Any recommendation for new Battery? Brand?
    Grazie
  2. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    Interstate.
    This topic has come up a lot -- you might use the 'search' feature to get a week's worth of reading.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    That weeks worth of reading will also say Interstate
  4. magnum15
    magnum15 Karting
    Oct 31, 2005
    147
    Tucson,AZ
    Gary
    Interstate it is (did search...not much substance)
    Tks
  5. miketuason
    Feb 24, 2006
    15,812
    Cerritos, CA.
    Good choice, that saves you weeks worth of reading:D
  6. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    I guess I'm the odd man out. I have an Optima Red Top. Heard of some people using deep cycle marine grade batteries with good results.
  7. Bullfighter
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    What's a 'battery' thread without disssent? :)
  8. DGS
    DGS Seven Time F1 World Champ
    72,047
    MidTN
    DGS
    Wouldn't that be, "What's a battery thread without a negative?" ;)
    (Nerd humor)
  9. 308 GTB
    308 GTB F1 World Champ
    11,729
    New Jersey
    Barry Wolinsky
    No you're not, Doug. I've had dependable service from my Red Top for the past five years without the use of a battery tender. I drive my car regularly, year round. The Optima Red Top is designed for regular use.
    Barry
  10. DGS
    72,047
    MidTN
    DGS
    Even with a battery tender, my three year old Red Top has a hard time cranking the car. I'm going with Interstate. (But then, I also want to swap out that battery hog recovery system.)
    So how many people with "trouble free" optimas have recovery systems or alarms (that they use)?
    I can use just about anything in the Alfa -- it doesn't even have a clock. When it's off, it's *off*.
  11. DGS
    72,047
    MidTN
    DGS
    (crickets chirping in the silence) ;)
  12. Simba
    Simba Formula Junior
    Oct 24, 2006
    779
    New York
    Slight thread resurrection, but--
    I have a yellow top in my 355 with a very hungry alarm, GPS, stereo, etc, etc, and it's been trouble free for over two years now. Same deal with many of my other cars with even higher idle power demands.
    The issue with the optimas, I find, is that they really don't like being left in a state of discharge for very long. If they're kept above 11v (e.g. drive the car), they're great.
  13. f355spider
    f355spider F1 World Champ
    18,047
    The size is a Group 34R. Some Group 34's will fit if you reverse the battery around, but careful, sometimes the cables will not reach the terminals. The only difference between the 34 and 34R is the terminals are reversed.
    If you can get a Group 34 to fit, I would highly recommend a Sear Platinum absorbed glass mat battery. It was the highest rated battery in recent Consumer Reports testing. 4 year free replacement warranty, totally sealed, so it can never leak battery acid. 880 cold cranking amps. Maintenance free. Low internal rate of self-discharge, so it can sit for weeks and months and still start. Not cheap, about $189 or so.
    http://www.sears.com/shc/s/p_10153_12605_02850034000P?vName=Automotive&cName=Batteries+%26+Chargers&sName=Automotive+Batteries
  14. 308 GTB
    11,729
    New Jersey
    Barry Wolinsky
    Famous last words, I guess. Anyway my >5 year old Red Top died last month. All the posted issues with the current Optimas considered, I replaced it with an Interstate.
    Barry
  15. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    I agree with Bullfighter it's good to hear differing viewpoints, I use a redtop w/a tender....BUT the bigger issue is; should we change our belts every time we replace our batteries?
    Just could not resist
  16. DGS
    72,047
    MidTN
    DGS
    I had the same die hard in the Alfa for 13 years. Two years isn't even the warranty period. ;)
    Anyway, I had that "alarm" (actually remote kill) system removed -- it was a lot of the cranking problem by itself. I'll see how the red top does with just the stereo memory (1ma) and clock. But there's an Interstate dealer on the corner, so the optima is on probation. (It's three years old, now. :p)
  17. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
    Optima Red Top with a trickle charger; same battery for the last seven years without a problem...
  18. DGS
    72,047
    MidTN
    DGS
    Well, if the battery warranty is five years, and the belts change interval is every three years, ... ;)
