Battery for 3500 GT? | FerrariChat
Discussion in 'Maserati' started by 61 3500GT, Nov 19, 2017.
Tags:
  1. 61 3500GT
    61 3500GT Rookie
    Mar 1, 2016
    14
    London, England
    Can anyone offer advice on the correct battery to fit to a 1961 3500GT? I've recently fitted a new 60aH battery and the cranking speed is very low - so I'm guessing more power is needed. Any advice on what the amp hour rating needs to be would be very helpful. Image Unavailable, Please Login
  2. eogorman
    eogorman Formula Junior
    May 10, 2005
    334
    Buhl, ID
    Eugene O'Gorman
    Even a small battery should be OK when new. I would check the ground and the connection of the long cable to the starter. I fit the largest battery that will fit the compartment because it looks better.
  3. 61 3500GT
    61 3500GT Rookie
    Mar 1, 2016
    14
    London, England
    I checked the ground lead and found it was close to breaking - in fact it completely separated from the ground post. Put a new cable on and it's now starting fine. Many thanks Eugene!
