hello: I am in the market for a battery for my Mondial T, Can anyone give me some specs as to what I need as far as amps, brand, etc. Thank You Frank
Francesco- The OM and WSM both state either a FIAMM low maintnenance or Delco maintenance free battery was fitted, 66-70 AH. The FIAMM references I have show an L3 80+ battery for the Mondial, but not the T, which cross references to the following batteries: Mondial/TR/512 TR/F512M/355/456/456M/550/575M/599 Battery MTP-91 Interstate (More Power, Cheaper, Lighter, than MTP-H6) Product ID: MTP-91(Automotive Truck) Amps: 875 Cranking Amps: 875 Cold Cranking Amps: 700 Voltage: 12 Termination: A Pro-rata Warranty: 85 Weight: 36.9 lbs Width: 6.88” (175 mm) Length: 11.38” (289 mm) Height: 6.88” (175 mm) Retail Price: $124.95 MTP-H6 Interstate (Alternative) Product ID: MTP-H6 (Automotive Truck) Amps: 800 Cranking Amps: 800 Cold Cranking Amps: 640 Voltage: 12 Termination: A Pro-rata Warranty: 85 Weight: 40.8 lbs Width: 6.89” (175 mm) Length: 10.94” (278 mm) Height: 7.48” (190 mm) Retail Price: $163.95 Delco 48-6YR is a substitute for the MTP-91 Hopefully someone can confirm whether the same batteries fit both the Mondial and Mondial T. If you do not have a Mondial T WSM, you can download it from this site: http://www.ferraridatabase.com/The_Downloads/Manuals_Workshop.htm Taz Terry Phillips Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
