Battery Gremlin | FerrariChat
Battery Gremlin
Discussion in 'Technical Q&A' started by gardnerld, Jul 5, 2006.
  1. gardnerld
    gardnerld Rookie
    35
    naples
    Larry G.
    Need help gang, it's finally happened to me. Battery powers all electronics but not enough to start vehicle. I have a 2003 360 coupe. Battery tender on vehicle and showing battery charged. After getting car started and driving it still was barely able to restart so believe battery not taking charge from any source. Re tried the battery tender and again showing charged but not enough to start. Time for Optima? Would like to know model that will work for my application.
    Thanks for the help.......
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    An 03 is pretty new for a battery change, but it's possible! Make sure your alternator belt is properly tensioned, because that would cut down the charging. The Fiamm factory batteries are not so great
    I used an Interstate MTP-91, and boy does that spin that engine over! I know there is an Optima model that fits well. I'd do a search for 360 battery to find the number.
    I keep mine on the tender all the time, and it pays off!
  3. f355spider
    f355spider F1 World Champ
    18,055
    Sure sounds like a failing battery...I have used both the Optima and the Interstate...your choice. The Optima never requires checking of the fluid though, and can't leak. But a few folks have complained recently of short life and other issues with the Optima...so it seems a toss up.
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Great advice.
    I replaced mine with a Costco battery and was chatting with the service attendant there. He reinforced the idea that battery maintenance is imperative to extending the life of the battery as he has seen a boater who bought a new battery the previous year and then left it unattended over a long Seattle winter resulting in a dead battery the following spring.
    It is good that you are using the battery tender.
  5. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    If i'm correct the Optima 34R is the one for late model Ferraris
  6. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    He is lucky he got around 3 years out of that battery. Where i come from, 75% of batteries dont last 1.5 years. :D
  7. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    DAMN ???
    Mine is 4. years old and never had any issues with it.
  8. PAP 348
    Dec 10, 2005
    100,232
    Pap
    They are a funny thing sometimes. Personally, i think the battery that the factory fits, lasts the longest, without giving you any issue's. Then the aftermarket batteries after that are crap. My 348 has a battery dated early 2005, and its let me down 3 times now(flat) since ownership last November. Time for a new one. :)
  9. FerrariF1
    FerrariF1 Formula Junior
    Apr 29, 2005
    531
    Virginia
    Chris
    go with optima, it never failed me and i have it on evey car.
