Battery Ground Cable Switch | FerrariChat
Discussion in '308/328' started by FF8929, Jul 20, 2010.
  1. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Not sure of its proper name, but it's the 2-position switch next to the battery, that breaks the ground circuit, from the battery to the body.
    Anyway, my 83 Mondial wouldn't crank the other day, no lights, nothing. After charging for awhile, still nothing. On a hunch, I cycled the above switch a few times, and vio'la it's all better!
    Any similar experiences?
  2. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    They commonly give problems with age. You can replace it with an aftermarket battery cut-off switch, may require some creativity to install one nicely. Most just get rid of the switch and bypass it.
  3. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    on my 89 't' my just melted down the other day. Everything seems to work a little better now. I suspected that it was providing a voltage drop and do not plan on replacing it.
  4. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Eliminate the switch from the circuit!! I had the same problem with an '84 Mondial QV that I owned, had lots of electrical gremlins. I bought new positive and negative cables, and routed the negative side directly to the chassis, bypassing the switch completely. Make sure you clean the metal surface on the chassis really well with emory paper, so that the cable makes as good a connection as possible. I then sprayed the battery terminal and the cable connection at the chassis with a battery corrosion protectant.
    The switch, even when it is "working" puts so much resistance in the line that you are losing power. As soon as I made that one change, a lot of my problems cleared up, especially the starting problems I was having. Also, be sure to check the fuse panel -- the old Mondial fuse block is notorious for connection problems, delamination of the circuit boards, and burned out wires. You might want to re-route some of the high drain items, like the fuel pump, away from the fuse block all together.
    Hope that helps.
    BTW, old car rule of thumb -- 95% of all electrical problems can be traced to a bad ground.
  5. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Thanks for the advice. Glad I asked. That switches days are numbered!
