Battery Heatshield | FerrariChat
Battery Heatshield
Discussion in '206/246' started by TonyL, Jul 13, 2019.
  1. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    I have always wondered how the battery can withstand the huge amount of heat coming from the car radiator even where I live in the UK, for hotter climates it must be a worthwhile mod, so I decided to make up a heat shield. Easily removable for those that like concours exhibitions.
    Found a small piece of aluminium plate and cut it to shape and manufactured a small V groove where the front retaining stud is situated. This then slides into the battery carrier and is sandwiched and held in place by the top battery frame. The edges bent around the battery to deflect the heat past the battery
    On the face of the plate I cut some 3mm heat resistant matting and glued it in place.
    Works a treat and may help the battery from the tough environment.
    Tony
    sorry no pics as I got carried away and fitted it before I thought of sharing the idea! :-(
  2. racerboy9
    racerboy9 F1 Rookie
    2,650
    The my late model USA GTS has a factory heat shield. Just a curved piece of sheet metal welded to the battery tray.
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    is that original do you think?
    Tony
  4. racerboy9
    racerboy9 F1 Rookie
    2,650
    Yes, it is in the parts book and called riparo batteria.
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Nice one, thanks racerboy9 learnt something new today.:)
    I bet lots of them are missing though
    Tony
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  7. HMB-Dino
    HMB-Dino Formula 3
    2,282
    Pebble Beach, CA
    RonG
    I presume you meant Item #4...no numbers above ~35 in that parts drawing.
    synchro likes this.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    I have owned my 246 over 20 years and its never had one.
    I doubt that part is available and think the one I made is far superior :D
  9. racerboy9
    racerboy9 F1 Rookie
    2,650
    It is just a piece of sheet metal you could make in a half hour if you wanted to. The one you made actually has insulation. I don't know if the original is meant to deflect heat or just road dirt and rain coming through the radiator. Maybe both.
    synchro likes this.
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Thanks,
    I was more concerned about heat rather than deflect as the battery is only a few inches away from the radiator. Cannot work out exactly as I dont have all the data to hand but the leaving air temp in this area must be extremely high, guessing at least 80C + given the size of the radiator, fluid temp and mass flow.
    The heat shield I made does have a very good insulation matting to guard the battery. I guess it may also add a certain level of protection against stones too.
    Tony
  11. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Image Unavailable, Please Login View attachment 2799941
    Hi Guys,
    My late '72 Euro GT.
    'looks to be original, including OEM rust! It is slightly curved with a nearly-ninety degree flange at top & bottom, as depicted in the Tav.
    Cheers,
    Coop
    TonyL and synchro like this.
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Exactly.
    I included the part number hoping somebody could come up with a price and astound us all at what king's ransom might be charged!
  13. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    thanks, would need a better heat shield in reality as that would stop diddly squat. Typical 70's engineering solution!
    Tony
    PS don't you have a battery retaining top bracket?
    synchro likes this.
  14. celestialcoop
    715
    Coop
    Hi Tony,
    Busted!
    Mine is missing. I have been relying on the 'gravity retainer' to keep battery in place. Fabricating a new one/finding a replacement has been on my to-do list since I got the car. Obviously, I've yet to get around to it.
    'super easy to make from scratch or modify an existing part. There may be a drop-in solution already out there, too. Any ideas?
    Thanks for the motivation,
    Coop
    TonyL likes this.
  15. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    sorry if I have made you more work!
    You could try Alberto, he had some made a while back.
    You may have to change the battery terminal. Mine has a very thick plastic sleeve over the terminal connector / boss [not the clamp] to prevent it touching the metal frame.
    Best Regards
    Tony
    synchro likes this.
  16. celestialcoop
    715
    Coop
    Hey, that's easy work!
    No excuse here; I should have taken care of it straight away.
    Great suggestions (insulation and Alberto),
    Coop
