Battery isolation and immobolise, Help! | FerrariChat
Discussion in 'Technical Q&A' started by Corsa308, Feb 24, 2008.
  1. Corsa308
    Corsa308 Formula Junior
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    I have just installed a battery isolation switch for track work etc.
    The battery disconnect part is all done and works fine.
    It also includes a separate switch at the base of the unit to disconnect the ignition.
    The point being that once the car is running and using the alternator, you can disconnect the battery but the car will still run.
    All the work is done, but i can't work out which wire/fuse/relay to disconnect with this separate switch.
    I can remove the fuses one by one and the relays one by one but the car still runs.
    I have studied the schematic in depth but can't definatively pinpoint where I should break a circuit.
    Seems strange that the coils are apparently unfused but never the less.
    Anyone done this before?
    Steve.
  2. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    Hello from Germany,
    the coils are indeed unfused and you have to break the circuit / wire coming from terminal 15 on the ignition key switch. DO NOT disconnect the battery while the engine ist running. This will almost immediately destroy the + - diodes inside the alternator.
    Best Regards
    Martin
  3. Corsa308
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    Martin, thanks for that.
    I had gone through the different connections to the ignition switch, 30, 15, 75 and 50 etc to try and work out their pathways.
    15 seems to run to the fuse block and then off to instruments and reversing light etc.
    Does it have another destination and hence will stop the engine?
    Any idea what these numbers mean?
    Also, do you have an explanation re the surge when the battery is disconnected while running?
    I do understand electrics fairly well and the islotaion switch does come with a resistor to connect to stop this occurence.
    My only paranoia now is that due to an existing isolation switch in the front compartment and hence following on from its installation, my new isolation breaks the minus connection from battery to the ground of the vehice.
    My theory was that this is the same as breaking the positive in a dc powered vehicle and a little easier, but how does that effect this instal of this resistor.
    Steve.
  4. Corsa308
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    Martin, after much grovelling undernetah the dash I can confirm that wire #15 (azzure) is the right one.
  5. windsock
    windsock Formula 3
    1,162
    If you use the disconnect on the ground side you spare yourself all this agrevation and it is actually safe as once the ground side is dissconnected there is no possibility of shorting anything. Using the possitive side if theere is damage between the shutoff and the battery you could still end up with a short to ground.
  6. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    In the 355 Challenge series, the extra switch was used to cut the field/exciter wire going to the alternator.
