Battery keeps draining every two days on my 348 | FerrariChat
Discussion in 'Technical Q&A' started by magspider, Jul 9, 2010.
  1. magspider
    magspider Karting
    Oct 25, 2008
    96
    Ontario Canada
    Ralph
    Does anyone know why my battery keeps draining out every two days.
  2. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Because there is something wrong? :)
    Seriously, I would suggest removing half the fuses and seeing if that solves the issue. If it doesn't, put those back and remove the other half. If that cures it, put half of that half back etc. It is called binary search.
    Alternatively remove one fuse at a time and see if there is a spark when you remove or put it back.
    This will identify which circuit is causing the drain, from there work on the items on that circuit. It is likely an alarm system or radio or even the alternator (bad diodes). The latter is what used to sap my battery on the GT4.
    Gerrit
    http://dino308gt4.com
    Have you hugged you car today?
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    #3 yelcab, Jul 9, 2010
    The faster way is to get a Digital Multimeter and use the A function (current function). You disconnect the negative terminal from the battery, and connect the DMM between the battery and the negative cable. Put the meter in the A mode, you should see an amp or so if your car is draining the battery in 2 days.
    Then, with the key in the off position, start pulling each fuse one at a time. You will find one fuse that, when pulled, drop the value from amps, to about 100mA or less. That is the circuit causing the drain.
    Find what that fuse controls, and start looking at the equipment attached to that circuit. One of them will be defective and draining the battery all the time at a high current. Fix that, replace that, and there is your problem.
    If you are lucky, it would be something like an alarm, a stereo, an amplifier, a dome light, or something pretty easy or obvious. If you are not, then it is a lot more obscure.
  4. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    How old is the battery and, is the charging system working properly?
    Before things get overly complicated, have the battery load tested and make sure the alternator is putting out the proper amperage to fully charge the battery.
  5. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Yup I'd go with Darolls suggestion first, then go with the meter. If the battery is more than 2-3 years old then it is probably at fault.
  6. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    By all means get the battery tested but if you are thinking of using a DMM to find the fault by measuring current, make darn sure that the meter can handle more than 1 amp. Many do not! It is easy enough to blow the meter this way.
    As to a couple of years out a battery, really? I expect to get 10+ years out of a decent battery, even from Canadian tire. My GT4 used to drain the battery in a week, replaced the battery and guess what? It was actually a bad diode in the alternator. now the car can sit all winter with the battery connected and it fires up nicely once the salt is off the roads.
    If you can't get someone to load test the battery, then disconnect it and see if it still drains in 2 days. If not then it is still in the electrical system.
    Gerrit
  7. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Somes you are lucky and can connect the current meter across the battery disconnect switch so it is easy to measure across the open switch without removing battery cables. I spent a couple of weekends chasing a 342 ma draw because various computer systems woke up and......and.........wait for it.........the stupid trunk wasn't latched down. After letting the systems go to sleep the normal current draw is 21 ma and no more dead battery! Another thing to keep an eye on is a connector under the air box that passes power to the starter...mine was coated with white arc stuff. FWIW
    Jeff Pintler
    89 348tb, 86tr, 99 360 3-pedal
  8. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    #8 Darolls, Jul 16, 2010
    Is it just me or do others feel the same?
    Someone asks a question and we take the time reply; then we don't get any response from the OP. Kinda makes me feel used and wonder why I bothered!
  9. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I've certainly noticed that, but the greater percentage (in my experience) has been appreciative of the help.
  10. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Because many actually express thanks.
    What bothers me is guys not responding with the answer they found to the problem. What they post is a puzzle and we try to solve the puzzle. Getting no feedback doesn't add to our knowledge base to help the next bloke with better information.
    Hows we flog those who ask and disappear?
  11. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Yes, its always nice to get feedback from the OP if they have resolved the issue or not. :):)
  12. ScoobyDoo555
    ScoobyDoo555 Rookie
    Mar 12, 2004
    32
    Dan Armstrong
    Well I'll say "thanks" then :D
    Haven't got my 348 yet, but now have a bit more knowledge on a potential issue :)
    My Ferrari knowledge is limited, but if you need assistance with audio, music, technology (I'm pretty clued up in this field), I'm your man :)
    Dan
  13. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Yup I'll say thanks too, to all. :)
    Dan, good to know your expertise.... Cheers :)
  14. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Ditto......
    Sparky
  15. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
  16. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    (...........), big group hug!
  17. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Well, gosh guys... some folks don't log on to their machine everyday, or get distracted with other things --- it's only been 10 days --- not too egregious.
  18. finnerty
    May 18, 2004
    10,406
    BTW, you're all wrong..... The answer is because "IT'S A 348" --- electrical problems are built into the design of that one -- LOL
  19. Night life
    Night life F1 Veteran
    7,311
    The city that rhymes with fun in Canada
    Roberto
    Usually with a really big stick :D
  20. Ferrari 888
    Ferrari 888 Rookie
    Jun 9, 2007
    35
    Calgary, Alberta
    Lorne C
    I am not sure if could happen to your car but I had the same problem with my 360 and it turned out to be in my amplifier for the radio and CD it had a short in it and when I got a new amp the problem stopped.
  21. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    #21 gerritv, Jul 19, 2010
    If it bothers you guys so much that he hasn't responded yet, send a PM.
    Personally what I contribute is my opinion. The requestor can use it or ignore it. And hey, maybe something came up like a lottery win or something that is occupying his time now? :)
    I'm just hoping that he heeded the advice to disconnect the battery before playing with the mechanism. Those up/down motors have lot of torque!!!
    I'm sure he'll pop up again.
    Gerrit
  22. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    It is NOT this one guy - he probably has a good reason - he is just the unfortunate example, came around at the wrong time.
    It's the general case...there is no animus to the OP. But when a puzzle is presented we like to know the answer!
  23. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    #23 Darolls, Jul 20, 2010
    You're right, he probably won the lottery and sold the car. Bought a private island where he now lives and runs around naked all of the time!
    By the way, I'm from Islington so my mindset may be different.
    Lucky dude!!!!
  24. Shaide
    Shaide Formula Junior
    613
    Las Colinas, DFW TX
    Jason
    This was basically the problem I was having with my 348. Previous owner had put in a stereo amp that was overkill for such a small cabin. Turned out the installer did just a bad job with the wiring that the battery was was draining in 48 to 72 hours. Once removed, all problems went away. It now has sat for as long as two months and cranks right up.
    If there is an aftermarket audio system, I would check/test the wiring on those devices earlier rather than later in the diagnostic process.
